Page 4 of 5 1 2 3 4 5
#1037723 09/07/04 06:39 PM
I'm going to throw a wrench into the works here. Not to be an antagonist, but, because I'm not convinced the issue has been properly approached yet, and, having written off my SVT and found another with a blown motor I considered going the 3.0L route. After very little research it became apparent that the same spun bearing problem is cropping up in 3.0L hybrids and non-hybrids. I'll be posing my thoughts as questions as opposed to statements of fact because they are simply my rambling thoughts and queries.
The issue of oil system inadequacy has been theorized about to a great extent but I've yet to see any concrete evidence to that effect. What is apparent is that the level of connecting rod failures (typically spun bearings) is way above normal levels. It would appear that the level of main bearing failures may be above normal also (albeit to a lessor degree). I can't see any flaws in Terry's logic posted below, if someone has concrete thoughts contrary to his statement, I'd appreciate hearing their ideas.
Originally posted by btrautman:
Posted by Terry Haines...BUT if it were oil starvation that caused spun bearings 'due to design' then an engine would have it 'from new'....This is a progressive thing...most engines spin rod ends between 65-85,000 miles...if it had 'bad lube'/bad pan/oil retained in heads etc etc it would have been like that FROM NEW!....
In support of Terry's assertions, I think most of these failures are coming well into the lifecycle of these motors. That doesn't mean that there isn't a comulative effect that gradually takes out the bearing but, there is no denying that if the problem is a design one than it would therefore be present from new.
I'd also suggest that the record of Bob Bondurant's Racing School SVT Contours appears to be fairly good. I don't have info on the entire fleet but as of 02/2004 they had three SVT Contours and none have had an engine failure. Two have had their trans/diff replaced but I repeat none have had an engine failure. Surely, we can't be suggesting that street driven SVT's w/spun rod bearing would have been exposed to more frequent high G loads than these vehicles. All 3 are 98's and one with over 14k (this would be virtually all track miles)is serial # ...WK100012!!! It is my understanding that none of these vehicles have any sort of Accusump system, but I don't know for sure, perhaps someone else out there could add to this.
Our motors really don't have alot of racing background in NA compared to Europe so perhaps our fellow enthusiasts across the "Pond" could let us know if there has been a problem with spun bearings there and if they typically do or don't use any system like the "Accusump" one in the BTCC where I believe the Mondeos were quite abundant.
Originally posted by Sandman333:
Could the apparent lack of oiling problems in the 3.0L engines also but due to them being used in vehicles not likely to see high lateral G-forces (Taurus), or being mounted longitudinally (Escape)?
This appears to be no longer the case. My mechanic alone, has seen atleast half-a-dozen Escape 3.0L's with spun bearings in as many months. One had 4 bend rods!
Aside from the Zircon issue, there appears to be an issue of some failed rod ends being measured larger in size than stock. Does anyone know, for a fact, if this is something that could happen at the time of failure as a result of the failure.
Regarding the Zircon issue, while I completely follow Demon's logic that if it were due to a contaminant that the first place that would likely be affected would be the mains, followed by the rods next in-line, rather than those last in-line. This would make sense if the Zircon was large enough to "catch" on the main bearings or to fall out of suspension at that point. I have no idea what sizes we're dealing with here. Does anyone?
I also don't have my SVT Manual handy so perhaps someone can fill me in on the tolerances for the mains and the rods. Sometimes mains have more room than the rod bearing. The larger mains actually can be more forgiving of contaminants than the smaller rod bearings.
It is also possible that if there is "casting" sand finding its way into the oil that it creates a problem at the last bearing (does anyone know if these particles are small enough to go all the way through the system and finally be caught in the oil filter?
Finally, the absence of sand particles in the filter or in an oil analysis may not prove anything. If these particles are small enough to get all the way to #6, then the problem may be a cumulative effect that merely accelerates the wear at that bearing and the evidence could have been flushed from the oil/filter/system at some previous time but the damage had been done and the subsequent failure was a result of that previous damage.
I think a forgot to ask questions like I said I would and just rambled on. Hopefully this makes sense. (I've discovered that I sustained a concussion when I wrote-off the SVT and now have Post Concussion Syndrome - fancy phrase for saying my thinks is all mixed up - hopefully not too much of that here )
Regards, Alan
03 Volvo S60 2.5T AWD 98 Mystique 2.5 MTX 99 SVT - Inheriting Lil Monster's parts 98 SVT - Lil Monster (RIP) 183.7 whp Quaife/Fidanza/UR UD Clutch AFE/MSDS/SHO-Y/Bassani/MagnaCore GC/Koni/22mmR/EndLinks/ES/ KVR Slotted/1144's/SS Lines/MASItaly
#1037724 09/08/04 04:41 PM
Z
Z
as i recall, most (if not all) of the BTCC Mondy's used a 2.0l inline four. not the v6
2000 csvt #1553 Black/Tan
#1037725 09/08/04 05:40 PM
9
Originally posted by DemonSVT:
1. Generally speaking you don't know what the hell you are talking about.
6. They are the SAME [censored]-ING parts (rods, crank, bolts, studs, etc) Let me guess you heard this where you heard everything else right.
Doesn't that make it ZERO for 6...
Folks if you just don't know then please stop posting your _______ comments. Just sit back and learn something...
Mostly correct, but the 2.5L and 3.0L do have different cranks. Yes, same stroke but a 2.5L piston is 296 grams and a 3.0L piston is 348 grams, thus requiring the crank balance to be different. Hence totally different parts, part #'s and applications.
#1037726 09/08/04 05:51 PM
It is the exact same forging and the response was to the strength of the crank be it 2.5L or 3L. (which has supported over 1200HP btw)
The 3L has heavier counterbalancing. (which I have stated on numerous occasions to the point of even recommending it)
The balancing process (adding & removing weight) is done "after" forging.
Hence the exact same part to begin with, buy yes a different part number & applications. All of which I have stated before.
So what exactly was your point?
#1037727 09/08/04 05:53 PM
Actually it was a destroked 2.5L V6 displacing 2L.
For that matter the first several years it was a Mazda engine then latter replaced by the Duratec.
#1037728 09/08/04 07:04 PM
9
I think it is pretty obvious to most people, but my point is that "SAME" does not equal "different".
In regards to strength and resonant frequencies etc, there are probably some small differences as well.
Ex: Should you put a 2.5L crank into a 3.0L block?
NO!! - the 3.0 crank is a different part designed for a 3.0L piston mass (same forging even if true is irrelevant)
Just trying to correct some mis-information.
#1037729 09/08/04 07:08 PM
Webmaster
Webmaster
The pressure may fall everywhere at the same time as in the sprinkler example, but the pressure on the end of the crank (#6 rod bearing) is lower to begin with, right? It dips below what is required to keep the rod end coming into contact with the bearing, and *boom*. All it takes is a little dip in pressure and the one(s) with the lowest is/are at risk.
That's my 'uneducated' stab at it.
-Lance
Lance Kinley CEG Webmaster 95 SE, "Cassandra" 10 years!
#1037730 09/08/04 09:57 PM
speaking of those, I don't think the sprinkler example can be seriously applied to small passages and viscous fluid... And even if it can be, the fact that the last sprinkler will START last -- as TAH stated -- means that #6 will not be lubed for the longest time. I don't think it will fail on the first time ever either -- production engines are not built that way. at some point it will say that enough is enough.
#1037731 09/08/04 10:01 PM
Well there are alot of words being said , but no numbers being posted.
What is the I.D. of the oil passageways?
What is the pump displacement?
Is the oil pump variable or fixed dispacement?
What is the choosen RPM, GPM, PSIG at a given time?
Considering the pressure is not constant we'll need to choose a given pressure at a given RPM.
Oh and considering the passageways aren't straight as an arrow that adds to the mix. And then theres viscosity, tempature.......
Well just to give you guys an example of what we're dealing with depending on the I.D. of the passageway......
PSIG loss goes up so does the GPM(flow)
on a .098in hole @ 1FPS the PSIG loss is 2.271261 & .0237GPM
But as I.D. increases PSIG loss decreases at a much lower rate and flow increases.
on a .236in hole @ 1FPS the PSIG loss is .394316
& .1366 GPM
These are for a known GPM of a fluid with a viscosity of 155SUS and a specific gravity of 1.0
These numbers obviously don't take into account tempature,viscosity,Id roughness and bends etc.
I don't know what kind of pressure drops everyone is thinking and hoping to see at a given distance,but it's not a whole lot. There is probably more variance between pumps from given times of assembly. The thing to test here would be the pump alone on a test stand to see a baseline at a given RPM.
The worst thing is that there is some Ford engine engineer with a big fatty file with all this info collecting dust somewheres......more like probably shredded years ago
06 GMC Sierra 2500HD Dmax/ally 06 Pontiac G6 GT 05 CRF250R FOR SALE 06 KX65 with riding gear $2700 obo
#1037732 09/09/04 12:12 AM
E
E
By the looks of a picture I saw, the Bondurant Contours, had a Accusump mounted in the area where the stock cabin air filter is.
