Well there are alot of words being said , but no numbers being posted.
What is the I.D. of the oil passageways?
What is the pump displacement?
Is the oil pump variable or fixed dispacement?
What is the choosen RPM, GPM, PSIG at a given time?
Considering the pressure is not constant we'll need to choose a given pressure at a given RPM.
Oh and considering the passageways aren't straight as an arrow that adds to the mix. And then theres viscosity, tempature.......
Well just to give you guys an example of what we're dealing with depending on the I.D. of the passageway......
PSIG loss goes up so does the GPM(flow)
on a .098in hole @ 1FPS the PSIG loss is 2.271261 & .0237GPM
But as I.D. increases PSIG loss decreases at a much lower rate and flow increases.
on a .236in hole @ 1FPS the PSIG loss is .394316
& .1366 GPM
These are for a known GPM of a fluid with a viscosity of 155SUS and a specific gravity of 1.0
These numbers obviously don't take into account tempature,viscosity,Id roughness and bends etc.
I don't know what kind of pressure drops everyone is thinking and hoping to see at a given distance,but it's not a whole lot. There is probably more variance between pumps from given times of assembly. The thing to test here would be the pump alone on a test stand to see a baseline at a given RPM.
The worst thing is that there is some Ford engine engineer with a big fatty file with all this info collecting dust somewheres......more like probably shredded years ago
