#1036698 08/28/04 02:47 AM
V
V
99 Ford Countour 2.0 temp normale on highway but overheats on streets. Notice cooling fan wasnt kicking on. I have a Hayes manuel but it has the wrong diagram for the engine relay. Does anyone know which relays for the cooling fan are the high and low ?
99' royal purple contour
#1036699 08/28/04 03:28 AM
the Sending unit in the Zetec's are kind of wierd... MOST of them are telling you its at the top of the heat spectrum when its really closer to the middle. Next chance you get, start your car up and let it idle and wait till it goes to about the "L" on normal. and listen for the fan to kick on... if it does, then your sending unit is telling you the wrong reading in the cluster. if the temp continues to rise and the fan does not kick on... Then I would say replace your Thermostat.. its pretty easy.
Edit: does turning the AC or Defroster on turn on the fan? and does it make the temp stay down?
#1036700 08/28/04 12:39 PM
The low speed fan resistor is a common failure.
I recall it having been discussed in the past. Perhaps you can locate these discussions by searching around.
Steve
#1036701 08/29/04 07:38 PM
V
V
where is this resister found???do you have a picture?
#1036702 08/29/04 09:53 PM
N
N
I have the diagram of the electrical cooling system for a contour 99 2.0 with A/C and the battery junction box pictures that shows you exactly where are your two relay and the resistor but i don't know how to send pictures. So e-mail me if you want the information or tell me how to post them.
Nic.
Contour 99 MTX V6 fully loaded, stock with 110000km. Illuminated sunroof switch. About to do the mystique rear dome light conversion with eyeball dome light.
#1036703 08/29/04 11:14 PM
9
9
Would a 96 zetec also have this sending unit.If so where would it be located?I dont want to hijack this post but I have the same problem.My guage goes all the way to the L then the fan kicks in and it just stays there it doesnt go down.I was thinking it could be the coolant temp sensor.
#1036704 08/30/04 01:49 AM
It's near the bottom of the radiator, on the driver's side corner, facing toward the engine. You can trace it by locating the motor on the cooling fan, and then following the wires backward.
#1036705 08/30/04 02:44 PM
W
W
Both cars have 180* thermostats. The temp gauge points straight up BUT every so often (Small hill) the needle rockets towards hot. The engine coolant as not reached the fan on temp(fairly high). As a test I turn on the A/C(starts the cooling fan automaticly) and I observe the temp needle as it returns to straight up. SO....everything is operating according to Ford spec. Sometime one has to just look away....
2012 Lotus Evora --------- 95 Mystique MTX - GONE 395,000 Kms --------- Both Zetecs '97 Contour Mtx - stock - GONE
#1036706 09/02/04 01:34 AM
V
V
Eh nick on the cooling fan diagram the dual pressure switch N76 is that the a/c switch? do you know of any specs for the switch and where is the ect shouldn't that be apart of the diagram
#1036707 09/02/04 02:38 AM
N
N
Honestly i'm not sure, i can have u the imformation on the connector and the switch, in maybe a few days (1-2days)
And i don't anymore have my access to the information, i've kick out from my job and my account has been suspended. I'll give you the information soon if you still need em.
