(from the list)
I think I've finally found an exhaust setup I like.
Like the dual sidepipes I just did, this one is a seperate 2" pipe off of each manifold. However, this setup goes straight back under the gas tank. Each pipe goes to a mini dynomax super turbo mounted on each side of the spare tire well. There's no crossover or balance tube at all on this setup.
Unlike other dual systems out there - this one only has a slight crush bend for each pipe to angle back up at the gas tank, and the passenger side has a pair of mandrel bent 45's on it. Everything else is straight pipe.
Ground clearance is not bad at all - about the same as my neighbor's stock S2000. I've gone over several speed bumps without a hint of scraping. (For that matter - I used to drive a 79 t/a that had less exhaust ground clearance than this, as I found out on
a rough rail road crossing once. Ouch.)
Power level is good and sound dampening is quieter than I've had since first bolting on the garbage pacesetter catback last summer.
I'm actually amazed at how quiet it is.
Here's the cool part. The sound coming out of this setup at full honk has a very nice quality to it - I've certainly never heard a
duratec sound like this. I'll try to get some sound clips, but those never seem to do real life justice. Those folks planning to attend the tail of the dragon run in October will get to hear it tho. Maybe someone there can get a good clip using a video camera or
something.
Oh, and one other thing - I've had to yank the superchip to get best power from this setup. It seems I'm now flowing more air than the superchip profile is set up for. Car was lots weaker at WOT with the chip in. Guess I'll have to go for a custom tuning setup now.
Here's a pic from the front:
And here's the rear:
Hope some of you find this useful or entertaining,
Dan Beggs
99 Cougar V6, more neighbor-friendly now
