Numerous possible locations here. If the water came in while you were driving, than I would say it was the two cabin air vents that vent from the trunk to the ouside. They are behind the carpetin on the side walls of the trunk, a little way down. Ford used foam gaskets, whiuch crap out very easily. Remove, clean, reseal.
Anothger place is through the tail light housing. It's the same type of deal, cheap gasket. I pulled the housing, cleaned it all up, and laid down some silicone to seal things up. Then I reinstalled the light housing and have no more leaks. Good luck!
98 Silver Frost SVT
97 BMW 540I Sport, six speed
"Blue is for sky, black is for soil, and white is for simplicity, purity and hope for the future"
"A coveted car should never stunt your life, but should make it more rich and interesting."
