#1034420 08/25/04 04:34 PM
To those with experience tuning, What have you found the optimal a/f ratio to be for a 2.5L N/A Svt motor?
98' Contour SVT lots of go fast mods check em out: http://www.prism.gatech.edu/~gtg285m/
#1034421 08/26/04 01:30 AM
I had an urge to post the following for some time, so this question might be a good excuse. I'll take the pictures down in a couple of days, so save them if interested. Chapter "Mixture formation" on page 4 is directly relevant.
Full article:
p.1
p.2
p.3
p.6
p.7
p.8
p.9
p.10
#1034422 08/26/04 02:11 AM
You posted all of that just to say that the theoretical ideal A/F is stoich?! Good lord!!
99 SVTC, T-Red, #652/2760-12.8.1998 Mother#@%@!* did I sound abstract? I hope it sounded more confusin than that!
#1034423 08/26/04 02:19 AM
good point. I replaced pictures w/ links. Sorry.
I don't think that the text is as straightforward as you make it sound, though.
#1034424 08/26/04 03:37 AM
~14.7 to 1 is optimal
#1034425 08/26/04 04:49 AM
i was under the impression that A/F ratio changed at different levels of throttle and rpm. Am i completely wrong?
TPC Northville, MI 2002 - Pitch Black Focus SVT (Red Trim) Steeda Short Ram Intake 5% Tint All Around 98 Contour SE Zetec ATX - *RIP* @ Charity Motors
#1034426 08/26/04 03:21 PM
no you are correct in that at different RPM and throttle openings the air/fuel mixture changes, but that is what the o2 sensors are for they monitor the mixture in the exhaust gas and then adjust timing and fuel injector opening accordingly
98.5 Black SE ATX S&B filter, SVT MAF, optimized SVT TB, mesh grille, removed orange reflectors, painted rear reflector, gutted pre-cats, optimized SVT LIM, 19lb injectors, resonator removed cant afford an svt but lookin for 1 in nc
#1034427 08/26/04 03:52 PM
The A/F ratio is in a constant state of chance.
That's why it's called adaptive fuel control.
The target number for normal load (40-60%) is stoich. 14.7
No load/engine braking has no fuel trim. You can see 20.9% oxygen (open air)
Low load is leaner then stoich. (15-16)
Moderate load is slightly richer. (13.5-14.5)
WOT is richer still. (12.8-13.3)
Boosted WOT is even richer. (12-12.5)
The person that asked the question made it a "General" question.
They never said what the engine conditions were so the answer of stoich was and is correct for that question.
#1034428 08/26/04 04:11 PM
Thanks demon. I guess I didn't ask the question correctly. So for dyno tuning I am assuimg you would be tuning for WOT and you would want a ratio of ~13:1?
#1034429 08/26/04 04:50 PM
Yup low 13's/high 12's is what you should shoot for.
1999 3.0L Cougar: 220fwhp and 200tq 2003 VW Passat W8 with 4 Motion AWD http://www.cardomain.com/ride/300644 PM for intrest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, or anything 3L related.
