Page 1 of 3 1 2 3
#1034173 08/25/04 05:17 AM
So after spending the entire afternoon weighing my car in multiple different configurations I have come to several conclusions.
The 3126lbs listed by Ford is likely quite accurate for a fully loaded SVT with full fluids.
I back calculated verses the weight I removed and the weight push from my engine & tranny work.
The Jack & Spare weigh a lot more then I thought. (42lbs)
The weight on the front wheels increases noticeably as you remove weight from the rear. Again more then you would think.
Removing the fold down seat backs saves a lot of weight (34lbs)
Removing the back seat is really a waste. (maybe 8lbs for the seat bottom and it's a PITA to put back in)
Moving the driver's and passenger's seats back helps front to rear weight balance more then you think. Lay the passengers down. This weight balancing is for autocrossing.
More weight on the front isn't a bad idea fro a FWD at the drag strip.
An Optima in the rear right corner of the trunk helps autocross weight balance considerably. (I test fit mine and removed the dynabatt for weighing purposes)
So what did mine weigh???
I weighed it no less then 12 different ways. (shut up Brad, I can hear it now )
Normal Street Trim with Driver & a Full Tank of Fuel: ~3200lbs
Front: 61.3%
Rear: 38.7%
Left: 51.2%
Right: 48.8%
Yes that includes a few nonessential items but it's how I drive it on a daily basis.
No Jack, Spare, Mat or Rear Seat Backs & Car cleaned out with 1/2 Tank of Fuel: 2905lbs
Front: 63.9%
Rear: 36.1%
Left: 49.9%
Right: 50.1%
With Driver: 3090lbs
Front: 63.3%
Rear: 36.7%
Left: 50.9%
Right: 49.1%
I consider that the "best weight" I will go.
Removing the rear seat bottom and both STB center bars was worth ~10lbs.
Running only 5 gallons vs 1/2 tank of fuel is worth 12-15lbs.
I didn't bother removing the passenger's seat but that would be another ~15-20lbs.
So "technically" on a full strip & running fumes it could be a svelte 2870 or so.
Also using these numbers I calculated my weight when I went to the track last spring at ~3165lbs. (~10lb heavier Driver + No jack/spare, normal street trim and a near full tank)
I have a neat excel sheet of the weights on each corner and cross weights and percentages for the many stages of removal.
I plan to post it on my website. It would make a good tool to see what weight changes do to the balance of the car for folks planning that type of modification.
#1034174 08/25/04 07:16 AM
Good information! Thanks for posting the findings of your research.
Just to clarify (and correct me if I'm wrong), but that should be for weight removed from behind the rear axle line only (as opposed to the back half of the car), since anything just forward of the rear axle line will have its weight distributed to both the front and rear wheels. What that also means then, is that the net effect of removing the jack/spare and other junk from behind the rear axle line is not only the benefit of less overall weight, but also the transfer of more weight to the front tires for traction. Double bonus for drag racing!
Marty
98 SVT, Black, No. 786, May 7, 1997. K&N, MSDS, Xcal2, Tint, Antennas, Big Gulp(R)-Sized Cupholder, Rear Dome Lt., Koni/Eibach, DMD, Pre-98 Sails, Brake Cooling Deflectors, Sidemarkers, Etc. 147K+ Miles "Get the Door - It's GrooveNerd!"
#1034175 08/25/04 07:28 AM
JB1 Offline
so what exactly do you do for a living?
00 black/tan svt, #2052 of 2150, born 2/1/00 formerly known as my csvt "Nothing in the world is more dangerous than a sincere ignorance and conscientious stupidity." -Martin Luther King, Jr.
#1034176 08/25/04 07:55 AM
Heck, I just take mine to the truck weigh scales whenever I want to do a few runs with my G-Tech Pro.
#1034177 08/25/04 09:15 AM
Demon just likes to get down to Fun-D-Mentals with this stuff Good info
06 GMC Sierra 2500HD Dmax/ally 06 Pontiac G6 GT 05 CRF250R FOR SALE 06 KX65 with riding gear $2700 obo
#1034178 08/25/04 09:19 AM
i weighed my on one of the truck weigh stations i can't remember ho much gas i had in it, but it said 3060 nothing removed
98 contour svt #6473 of 6535
#1034179 08/25/04 01:41 PM
The ones on the expressway? Did you just drive up and yell out the window to the state police that you were just curious? Sorry...I've just never heard of doing this.
'03 SRT-4 50 trim turbo + support
#1034180 08/25/04 02:17 PM
I will definately take a look at the table. I'm especially curious about the battery & the weight distribution issues with that mod. Really didn't think it would make a significant difference, but if it does then that's a stronger argument for making the change.
Demon, you put a lot of time/effort into doing this kind of stuff, & I would like to express my thanks for making the info public. Mighty cool of you.
#1034181 08/25/04 03:16 PM
It always amazes me that something like this helps balance the weight, its an obvious thing I never thought of.
2003 Toyota Matrix 1972 Pontiac Ventura II "Sprint" 1998 SVT !SOLD!
#1034182 08/25/04 04:40 PM
I used some at a popular truck stop along the Interstate. Many truck stops will have these so loads can be checked before getting fined at the weigh scales. The service isn't free so expect to pay a few bucks.
Page 1 of 3 1 2 3
