Page 3 of 6 1 2 3 4 5 6
damn! I called quaife uk as it is only 60miles from me and they said it will cost me £558.12 plus shipping thats over $800 !! i explained what i had read and they said that it was due to the fact that quaife USA are ordering so many. can i here every body say Bull sh*t! how much would it cost me to order from quaife USA and have it shipped to the uk. nowhare near $800 i bet another prime example of the UK public getting shoved up the ass from greedy UK retailers. mad mad
Mondeo ST24 with RSAP body kit.
17" DOTz's on 215/40/17 goodyear F1's (very good tyre)
EBC TURBO GROOVE FRONT AND REAR DISCS (rotors)(warped fronts exchanged under warrenty)
EBC GREEN STUFF PADS (voted no1 in uk performance ford tests)
k&N induction kit
throttle body butterfly mod
SHM HEADERS, Y & CAT
Custom Exhaust System
Ecotec Valve
more mods to come...
ice sony XR-M510 head unit
sony 656 changer(cdr/cdrw/cdtext compatable)
Strange how the tables turn. Us U.S. customers former best dal was to have one shipped from the UK for $849+shipping. It was still a lot cheaper then getting one from Quiafe USA.
"If you're pushing crazy I'm all full up here."
{Black '96 Contour SE MTX w/ over 126k on the clock}
· Get the skinny here.
· Need a 96-00 Ford Service Manual on CDROM?
COBM Offline OP
Actually I got mine for $720 all taxes and shiping included (gif from my brother)
"You can turn a engineer into a sale man but, you can not turn a sale man into an engineer"
"I have walk to the valley of Honda and death for that I should not fear no V-tech"
99 cougar,SVT manifold convertion, Tranny upgrade by Haines Motor sports (Quaife lds, Fidanza flywheel, and Clutch Master Stage 3 clutch) 18" Axis Se7ends,GC coiovers,sho sho Y pipe,Wilwood4 piston brake kit
this sounds like the best deal ive heard in a whie.. if i keep my svt ill get one too
99 svt contour
-its fast. period.
91 mustang gt
-its faster. period.
86 Buick Grand National
- its way faster, double period!
Originally posted by Jason F.:
Take my word for it, it may not fit right in all 2.5 transaxles. mad
Any particular reason why it wouldn't fit in a MTX-75 in a 1999 Contour SVT?
Doesn't make sense. In my VERY limited understanding of the MTX-75 tranny, the BASIC design hasn't changed that much, though certain parts in it have gone through a number of revisions. Is the differential one of them?
Any takers on this one?
JaTo
Overland Park, KS
JaTo@kc.rr.com
99 Contour SVT
#143/2760
Modded to Taste
00 Corvette Coupe
Modded to Haste
Email I received from Terry this morning:
We have got to the bottom of the problem.The current 'correct' Ford diff
carrier bearings are 19mm wide,this transmission was built by Ford with
17.5mm wide bearings! F.A.G did agree the bearing did exist but is no
longer made so it sound like some MTX75 transmissions had a production
fix in the trans plant re save casings that have been 'over machined' &
too narrow for std 199 mm wide races!Even Ford tech line have no record
of these 17.5mm bearings.Thes carrier will be m/c to take the 'correct'
19mm bearings.Hope this input helps for future questions on the fitting
of LSD to MTX75.regards terry haines
Not that I understand the internals of a transaxle, but the jist is clear to me. Not ALL 2.5 MTX-75s will be like mine, I just got a SPECIAL one. The kind that needs a machine shop to fit a Quaife. However a 2.5 MTX-75 will need to be heavily un-shimmed to get it to fit right. So don't let your local Billy Bob's Trannies do the work for you unless they know what they are doing.
Thank you Focus RS! That is just awesome. The Contour guys get a break in the aftermarket! With the new price, that is the least expensive LSD they make - usually our aftermarket stuff is about the most expensive. I have wanted a LSD but felt it may be just too much extra cost. But now, I have to really consider this. Terry H., you are the only guy I would trust for the installation. Your website is unaccessable for me now. Can you give a ballpark figure (I understand you probably can't give a firm price) for installation if I drove to Michagan. My clutch and tranny are fine. Thanks.
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
Good things come to those who wait. smile
Too bad an LSD would kick me up a class in Solo II. frown
"Function before fashion."
'96 Contour SE
How do we find out what our tranny has and if it will work with the LSD correctly withouth modding it...?
Nik
1999 Mercury Cougar V6
KKM Intake,SVT TB, SVT Upper/Lower, 19lb injectors, Diablo Chip, MSDS Headers, Custom Exhaust, B&M Short Shifter, Progress Lowering Springs, 18" Axis TC's, OMP Strut Bar, AAM 24mm Rear Sway Bar, Koni Struts
15.09 @ 91.54(corrected, pre-SVT conversion, DiabloChip, and Injectors)
In respect of the bearing issue,you cant until its stripped but we,HMS Inc, can make it work!
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
