Page 5 of 5 1 2 3 4 5
Kai Offline
I can send pics, but I don't want to remove the intake tube, resonator, etc. Is that ok? I mean, would you be able to tell any thing from it? I guess I could remove them, though I'd preffer to avoid it. smile
EDIT: If I send pics do I get a discount when it's done!?!? wink laugh
I'm just messing with you. I don't expect a handout, you're doing enough for us zetec's in the first place! smile
Kendall
'97 GL Zetec ATX
" Nippy "
LOL, you don't need to take it apart, please take pics of the areas of concern, which are the IAT and the rear side of the valve cover.
Thanks very much.
Kai Offline
Thanks very much.
You've got mail, Chris!
I hope I got the angles that you need. If I didn't, or you need something else, please don't hesitate to ask. I have access to a digital camera almost all the time, so taking more pics is not a problem. Thanks!
Kendall
'97 GL Zetec ATX
" Nippy "
Got your email, thank you. Is there a chance you could unscrew or take out the IAT so that I can get a good look at the design?
That seems to be the sore spot at the moment. I'm thinking also about the valve cover breather issue. May have to run a tube over to the intake port.
Kai Offline
Sure! Um, what is the IAT? shocked I would assume that it means Intermediate Air Filter (but we all know what assuming does, don't we). It that is what it is, where is it?
Kendall
'97 GL Zetec ATX
" Nippy "
IAT = Intake Air Sensor
It's the the pair of wires going to the underside of the intake tube between the MAF and the centre resonator.
Kai Offline
Gotcha. I'll try to get those pics tomorrow. Apparently "T" was looking a lot like "F" when I thought it stood for filter! smile
Kendall
'97 GL Zetec ATX
" Nippy "
Kai Offline
You've got mail again, Chris! laugh
Kendall
'97 GL Zetec ATX
" Nippy "
Thanks again, Kendall. Looks like a threaded fitting will be necessary at an additional cost or I am thinking that a newer push-in style IAT may be able to be used instead as a retrofit. We could include these, if it will work, at an additional cost to the kit.
