Posts: 82 |
Sure, I have no use for it now.
Thanks again and great looking SVT.
'98.5 Contour SE - Zetec Powered '00 Focus SE rims with Toyo FZ4's Rickbrook Shifter Knob Bullit Gas Door Accel Coil with Ford Racing Wires KVR Cross Drilled Rotors with KVR Carbon Fibre Pads
Posts: 2,246 |
If the KKM fits, is there any price reduction on not taking the filter?
David Litsky AIM: DaveL225 My Car
Posts: 1,202 |
Originally posted by David L: If the KKM fits, is there any price reduction on not taking the filter? Well, as the price of the filter is discounted when purchased with the kit, we would only be able to reduce the price by $14.00. We really would rather sell the kit as a whole and not end up with a surplus of filters.
Posts: 82 |
Get it with the filter. The KKM does not fit but I modded mine to fit as well as the MAF and mounting assembly to make it fit. It is not something I would recommend to everyone. Chris is only doing this exception for me since I originally asked for the kit without the filter. I ended up taking the filter because we were not sure the KKM would fit.
Posts: 2,066 |
Originally posted by cawong11: [QUOTE]Originally posted by SoupMan: I seem to have gained some power. A similar intake system was dynoed with a ZX2 Zetec engine and gave approx 5+ hp which is pretty good. I'm assuming I got the same. QUOTE]
One slight correction. The ZX2 we tested gained over 10hp and 8lbsft at the wheels. Although we did install an Accel coil and Magnecor wires, they may account for 2 hp if that. The intake caused the bulk of the gain.
Here is the ZX2 dyno sheet with similar intake kit.
Chris, Where did you get the Blue Hoses from. I'm looking for some of that for my Injen Intake Pipe(Just like BAT). Can I buy some from you? Just need to pieces. Thanks, Justin
Posts: 1,202 |
Originally posted by jcboeckl:
Chris,
Thanks, Justin Justin, we purchase the hoses in kits with the TB couping, but not separately. We could sell you only the kit but don't normally, since we order enough of each colour to match the number of intakes we are making.
Posts: 2,066 |
What are the sizes on them? 3"
Posts: 1,202 |
Originally posted by jcboeckl: What are the sizes on them? 3" From your previous post, were you referring to the couplings? If so, they are 3" in diameter.
Posts: 730 |
Chris - Just noticed that 95-97 intake is "Under Development." Any projections as to when this will be released? And I'm just curious . . . what is the difference in the pre98 to 98+ that requires a different kit? Just wondering . . . Thanks, and great job!
Kendall '97 GL Zetec ATX " Nippy "
Posts: 1,202 |
Thanks, and great job!  Well, the problem raised is the IAT is a screw in for earlier model Zetecs and apparently, there is no room for the crankcase breather to fit. Could you please send me some pics of the under hood area of your vehicle so that I can have a look to see what needs to be done to make the kit work? Thanks.
