Posts: 1,202 |
Originally posted by SQPlus: You could do something to make the pipe stay cooler. As Nick said, wrapping...some kind of insulating. Seeing as how they KKM filter connects to the MAF directly and so does the filter on this setup...I imagine the two would be interchangeable. By visual inspection a Miks heat shield would have to be modified slightly to fit with that setup. Guess I'll be ordering one to be the guinea pig for the custom setup. :p I admit that the pipe does get hot but when we tested a ZX2 (soory not quite Contour related) with an air filter relocation kit, the pipe remained hot, close to the engine but the performance did not suffer. This was in 90 degree weather, last week. I would surmise that when at speed, the air velocity is high enough that the temperature rise of the air is very little, though the pipe is hot. Looks like the air passes fast enough into the engine without picking up much heat from the aluminum. Also we had the autotap plugged in and we found that the intake air temperature was only about 20 degrees higher than ambient. I guess what I am trying to get at is that as long as the incoming air is relatively cooler, the hot intake pipe will have little affect on the temperature rise.
Posts: 974 |
You could wrap the pipe with the black plumbing foam that goes around the water pipes. It would then act like a thermis and keep cold air inside colder longer.
2001 Cavalier 150-175 more kms per tank of same size Pioneer 12 CD Changer
SOLD Green 98 Mystique GS Sport Zetec ,ATX 885 Fogs mod. Hi beam mod. 205 15s
Posts: 546 |
Thanks for the info cawong11. Here in florida sitting in 90+ temps for 30min at a time sluggs the car down. Massive heat soak. Ill try a few different methods and give yall he results. When i recieve the intake that is : )
Nick F. 01 Focus ZX3 MTX borla, eibach pro kit and dampers, dual guage pod (a/f and volt), jvc kd-sh99
96 Contour GL atx-zetec Yes its a zetec, we were here before vtec, so we are not copying!
Posts: 184 |
Originally posted by Chris Hightower: Very impressive!! Now we need to put the filter in a box and pipe it to the fender (cool air). Got something going for that, Chris?
Good job! Something like this ?? zetec intake
1998.5 Prairie Tan contour,zetec,ATX KKM;Focus Sports wires;Steel grills;Dexcool;Mobile 1;4x 15" green neon;Pre-98 console;Recontented clock and door handle lights;Code Alarm Surestart LX;Tinted;Sony and Polk ICE
Posts: 2,657 |
If only I had that Turbo...  ...theres always next summer.
Posts: 926 |
Dyno that damn Contour! Power Power Power Power Power!!!!!!!!
Ben C '97 Zetec Sport ATX Pacific Green Fog Light Re-wire Many Mods My Site
You think you can beat this?.....Well, you probably can
Posts: 88 |
Thanx for all the comments on the intake. I have to say it's my first performance mod and it's probably the best thing on my car yet. I have considered putting a heat shield but then on the other hand I don't seem to notice a difference in performance when driving. When I get out of the car after 30 to 60 minutes of driving, I touch the pipe and sure enough it's burning hot but again, performance is still there even after 60 min of driving. I said I'd put a recording of the new sound coming from the engine. Here it is: Intake Sound BTW, I couldn't rev the engine higher than 3500rpm because IT'S AN ATX. GRRRRRR!!!! Also, for the guy from Ottawa. If you decide to buy it, it would be coming from Toronto.
SoupMan
Contour 1998 GL Sport, Zetec 2.0L Nice cover lights, Painted calipers/Drums, Painted wipers arms, 24mm AAM Rear Swaybar ... Eh, nothing fancy yet!!
Posts: 1,202 |
Finally got around to posting some new pics on the web site. Go to Zetec Intake to view the pics. More pics available in the instructions too. Zetec Intake Installation Guide
Posts: 82 |
Whoo Hooo!!! I just installed my CTA 3" polished aluminum intake! It took a bit of work but I did it. I even got my KKM filter to fit. Looks great and sounds even better. I will try to post some pics later this week.
'98.5 Contour SE - Zetec Powered '00 Focus SE rims with Toyo FZ4's Rickbrook Shifter Knob Bullit Gas Door Accel Coil with Ford Racing Wires KVR Cross Drilled Rotors with KVR Carbon Fibre Pads
Posts: 1,202 |
Originally posted by PeterH: Whoo Hooo!!! I just installed my CTA 3" polished aluminum intake! It took a bit of work but I did it. I even got my KKM filter to fit. Looks great and sounds even better. I will try to post some pics later this week.
 Excellent, Peter. Wanna trade the filter back?
