Originally posted by Silverbullet98:
...Even though the CSVT is a noninterference motor (meaning that the timing will be retarded if anything in the aforementioned decides to take a s*$t on you in order to not harm the rest of the motor)
the timing might be ok, but the valves hitting the pistons because the cams are opening at the wrong time will mess up your engine
and as for interference or not, i got no clue about what that is or what it matters
98.5 Black SE ATX S&B filter, SVT MAF, optimized SVT TB, mesh grille, removed orange reflectors, painted rear reflector, gutted pre-cats, optimized SVT LIM, 19lb injectors, resonator removed cant afford an svt but lookin for 1 in nc
