Posts: 73 |
Originally posted by Alan Coles: Originally posted by 99TourSVT: You are wrong about the OEM part being not prone to failure.
I've not run across accounts of failures here in the last two years, but perhaps I missed them.
Alan read the above post.
99 SVT Contour under 43k miles - For sale!!! pm for info.
89 Taurus SHO 90k miles
next....STI swaped Impreza
Posts: 283 |
Originally posted by 99TourSVT: Originally posted by Alan Coles: Originally posted by 99TourSVT: You are wrong about the OEM part being not prone to failure.
He's not said how it got bent. Perhaps it failed, but all the troubles I've seen so far have been from people not installing/removing them correctly (especially the DMD) or damaging them, rather than the part itself failing on it's own.
Perhaps ottawanker could let us know how it got bent.
Originally posted by ottawanker: Oh, and by the way, the reason I switched to the DMD was because my original crank pulley was bent, and making some bad noises.
Regards, Alan
03 Volvo S60 2.5T AWD
98 Mystique 2.5 MTX
99 SVT - Inheriting Lil Monster's parts
98 SVT - Lil Monster (RIP) 183.7 whp
Quaife/Fidanza/UR UD Clutch
AFE/MSDS/SHO-Y/Bassani/MagnaCore
GC/Koni/22mmR/EndLinks/ES/
KVR Slotted/1144's/SS Lines/MASItaly
Posts: 79 |
I really wish I knew how my old pulley got bent, but I have no idea. I guess it could've gotten hit by a rock or something, I doubt it failed on its own, but hey, anything is possible.
As far as I know, the pulley that was on the car was the pulley that Ford put on when the car was built. Since then it has had 9 years and 170,000 kms of abuse, and that may have had something to do with it, but it looked to be in good shape, just bent.
Posts: 73 |
Well...the damper wasn't the problem.
Here is the million dollar question...On the bottom rear engine mount; if the center piece of rubber looks like it turned with in the mount, could that cause a vibration? In other words; is the rubber part of the mount free to spin?
FYI I will be starting a new thread with this same question, I need to know fast.
thanks
Nick
