Posts: 268 |
In process of installing the MSDS Vortech spec headers in my SVT. Knew about the oil cooler clearence problem, so bought a sandwich adapter to add air-to-oil cooler. After the oem water-to-oil cooler was removed, discovered that direct replacement is not possible! The oem unit use an extra long oil filter boss. It's about 3-4 inches long, 1.5 x 22mm threads on both ends and an o-ring in the middle. Had to get oil filter boss from regular (non-SVT) Duratec. Not sure of part # for this, I,m getting work done at a local shop and they ordered the part. Just be advised that it is required. Should be readily available, as all (as far as I know) late model Fords use the same 1.5x22mm filters. I'm hoping to get car back in time for local SVTOA dyno day this sat. Getting Quaife and clutchmasters Stage3 clutch also. Next up: HD axles/cv joints.
98 evo 0 SVT #2999 of 6535 Silver Frost/Midnight Blue Lotsa bolt-ons
Posts: 3,562 |
Originally posted by randyj: Had to get oil filter boss from regular (non-SVT) Duratec. Not sure of part # for this... Assembly piece 6890 from the exploded view drawing PC00005 of the Duratec 3 liter, same as 2.5. Heheheheh, I was just looking at that drawing and read your post.
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 1,447 |
Thanks for the tip, gonna reattempt the header install soon, where did you get the oil cooler and how/where did you mount it?
Posts: 1,682 |
Originally posted by randyj: ...I,m getting work done at a local shop... pussy
Posts: 4,042 |
Originally posted by bret:
pussy STFU. I bet you won't say it to his face. That would make *YOU* a pussy. John
Posts: 1,181 |
Nice JVT. Just because someone isnt very mechanically inclined doesnt mean hes a pussy...it just means he doesnt want to f**k up his car, DUH! :rolleyes:
98 Merc. Mystique LS
Red Wings and US Soccer 0wn j00!
Posts: 268 |
I'm no wuss! I work 50-60 hrs/wk @ nite. I could've done the headers, but since I was getting the Quaife and clutch installed and the mech offered to do the headers at the same time, Why not?!? Haven't got an oil cooler yet. I just plugged the oil lines on the sandwich adapter and will do the cooler later. (And I WILL do that myself)
Posts: 1,592 |
pussy That was uncalled for!
Posts: 719 |
pussy anyone remember when CEG was civil? sigh....
Posts: 4,319 |
pussy Hey Bret, you kiss your husband with that mouth?
1991 GVR4 Lots of mods done.
