Posts: 54 |
When I took my car in for the 90K service, they told me the Idle Air Control Valve is sticking and it was causing them to have difficulty starting it. I've never had any trouble starting the car...is this something i should worry about? Also, is it possible to clean it rather than replace it and how hard is it to replace?
Posts: 54 |
oh yeah, I have the V6 by the way
Posts: 2,725 |
Check the FAQs, there is a HowTo to clean it. All you need to do before removing it is by the gasket which is about $1. by cleaning it you will prevent the thing from having a cold start stall, which when stuck open/closed can and most likely will happen.
Posts: 1,064 |
Cleaning is only a temp fix, I cleaned mine twice in 7 months. For the $39 from www.autozone.com you may just want to swap it out.
2003 Toyota Matrix
1972 Pontiac Ventura II "Sprint"
1998 SVT !SOLD!
Posts: 54 |
Is it a hard piece to take out and install?
Posts: 2,807 |
99 CSVT Green/Tan
# 84 of 2760
15.376 @ 92.00 MPH Stock
75,000Km
96 Contour GL
2.5L V6 ATX 170,000Km
Posts: 54 |
ok cool....so i should be able to do it myself then....where exactly is it located?
Posts: 1,064 |
2 10mm bolts, its kind of tight back there.
2003 Toyota Matrix
1998 SVT !SOLD!
Posts: 511 |
very tight back there....good luck with the bottom bolt. other than that, very easy to do.
AIM...BKapp17
98 T-red SVT
Steeda
Gutted Pre-cats, no resonator
Painted Dash
Angel Eye Fogs
Painted Chrome ring / headlights
Looking for a t-red pre98 trunk lid
Posts: 2,203 |
Eh, not that bad, just angle the IAC valve top section to the passenger side of the engine bay, leaving more room to get ur 10mm socket on that bottom bolt.
