Posts: 2,203 |
Can we just accept Alan Coles' word as final, and end this thread? The guy knows his stuff, it all made logistical sense to me, and it's not worth fighting the unwinable fight.
Posts: 568 |
Originally posted by Kremithefrog: Nothing wrong with despising autos, but you can engine brake with them.
Sure. I didn't say one couldn't engine brake with a slushbox. It's just that with most, it requires excessive and unnatural intervention on my part. After 17 years behind both, I give the satisfaction derived from engine braking a slushbox a 2 out of 10. And the last thing I'd want to be doing is generating more heat in that fluid coupling hanging off the back of the motor by using the transmission in such a way.
B. Riley
Melbourne, FL
'01 Camry LE V6/5-spd
Was: '00 Black/Tan SVT Contour #560 - Sold 3/26/03
Before that: '95 Champ/Blue Contour GL V6 ATX
Posts: 21,653 |
From fourth to third, it just requires hitting a button for me. From third to second, just pop the shifter down, second to first, same thing. So yeah, I agree with unnatural, but not excessive. I also agree it shouldn't be done. But I occasionally do it (I'm talking less than 5 times a year) because dropping from fourth to second going around 40mph sends the rpm up to 3-4k and that's good for getting attention or just playing around. You know the cd4e is the best tranny ever, so no worries there.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 3,570 |
Originally posted by Kremithefrog: You know the cd4e is the best tranny ever, so no worries there.
rofl
Posts: 2,163 |
hmmm if I were driving in a very hilly area with lots of rolling hills with lots of curves should I down shift neutral when off the gass and slowing down shifting into gear only when giving the car some gas.
Posts: 283 |
Originally posted by contour_phoenix_when: hmmm if I were driving in a very hilly area with lots of rolling hills with lots of curves should I down shift neutral when off the gass and slowing down shifting into gear only when giving the car some gas.
No. You don't really want or need to be in neutral when driving on highways/byways/etc. Save putting it into neutral for when you're coming to a complete stop.
In very hilly areas you would normally want to be in one gear lower than your normal cruising gear, for the speed you are going during most of your driving. With one gear lower you are getting a bit more engine braking than normal when you lift off the throttle for a mild turn. If you want or need to decelerate at a rate anything more than that you should use your brakes and leaving it in gear.
If you are downshifting to exit a turn in a lower gear then you approached it in then, brake and have your downshift completed and your clutch pedal released just before you enter the turn while continuing to apply the brakes, remember to match your revs as you release the clutch.
As I've said before it's all a matter of degree. If the area is very hilly and the speeds are low then you could be in 4th, maybe even 3rd in some areas. Being from NY, you'd have to be quite abit upstate or south in the Blue Ridge area on secondary roads where the speeds are quite low to really use 3rd gear (carrying a load or very spirited driving could also warrant 3rd in some situations).
Take a weekend run across Hwy 90 toward Albany sometime. It's a nice road and there are some great side road excursions that have some nice rolling areas.
Regards, Alan
03 Volvo S60 2.5T AWD
98 Mystique 2.5 MTX
99 SVT - Inheriting Lil Monster's parts
98 SVT - Lil Monster (RIP) 183.7 whp
Quaife/Fidanza/UR UD Clutch
AFE/MSDS/SHO-Y/Bassani/MagnaCore
GC/Koni/22mmR/EndLinks/ES/
KVR Slotted/1144's/SS Lines/MASItaly
