Originally posted by Roz 1999 SVT-C: Ok I checked...mine kinda very's between 22 and 25...not a big diffrence....at WOT i hit 35-40 psi....hope this info helps!
Lupe
Ok, thats more like it, when my temp is higher than 180 i usually run around 37.5ish but when im under 180 under normal operating temp due to tstat..im usually upwards of 50.
Just wondering b/c I think when we "T"'d the sending unit when making a feed for the turbo, I dont think it is getting a proper reading now...only at idle is just under 12 like i said b4 and normal and wto is at 25ish...but when cold it is around 25 off as well, but I never lose oil pressure, it remains constant...so most likely messed up sending unit...Thank you for your help and feedback, just making sure my deduction was correct.
-Ken
'00 svt #1485/2150
Precision SC6152E .63 a/r, PnP Heads, TiAL 38mm Wastegate, Blitz BOV, HKS EBC, and HKS TT, Koni's Front/Rear, 19" Centerline RPMs, SPEC Stage 5 Clutch and Flywheel, DMD, Intrax, LoTek w/ Water Temp, Oil Press., EGT, Boost Gauge
