Posts: 153 |
I did a search and unless I searched for the wrong keywords (Oil Pressure), I didnt find anything that I was looking for.
All I really need to know, is what is our oil pressure supposed to read? Not necessarily WOT, but If I can get the stages ie... idle, normal driving and WOT that would be great..Thanks in advance for your help.
-Ken
P.S. '00SVT Contour
'00 svt #1485/2150
Precision SC6152E .63 a/r, PnP Heads, TiAL 38mm Wastegate, Blitz BOV, HKS EBC, and HKS TT, Koni's Front/Rear, 19" Centerline RPMs, SPEC Stage 5 Clutch and Flywheel, DMD, Intrax, LoTek w/ Water Temp, Oil Press., EGT, Boost Gauge
Posts: 1,145 |
haynes says oil pressure at 1500 rpm(hot) should be between 20-45 psi
98.5 Black SE ATX
Posts: 153 |
BETWEEN!? That large of a range isnt a problem? That sounds quite retarded to me, but ok.  -Ken
'00 svt #1485/2150
Posts: 3,506 |
Well it also depends where you take the messurements.
25 psi is adverage in the heads i have come to find out...but for a more accurate readings you want it in the block i believe its behind the bracket for the ac compressor or the alternator...from what i understand from there psi is between 40 and 45.
weight of oil your using is also a factor a higher weight will raser oil pressure.
the numbers i have given you are with 5w 30 weight.
Lupe
Posts: 153 |
so your saying by the egr area should be 25psi then correct?
-Ken
'00 svt #1485/2150
Posts: 3,506 |
Yes, i taped my Oil pressure sensor in the rear head, under the EGR. im reading 25 PSI when warmed up at idle.
Mobil 1 5w 30 is what i use.
Lupe
EDIT:::: Mind you, this is not the most acurate place to get a reading, as oil starvation issues happen in the pan...best place to put it is int he block itself...you get the most accurate and fastest readings.
Lupe
Posts: 153 |
ok, so 25psi idle..hmmm, i have never since day one had anything greater than 12psi on idle...im confused now...well what is your psi driving and at wot.
-Ken
'00 svt #1485/2150
Posts: 3,506 |
WOT honestly im not sure...never really paid attention to it at WOT..more worried about cars in front of me....i will double check the 25 psi at idle....but im pretty sure thats it.
Lupe
Posts: 153 |
ok, even w/ my 160tstat and the car fully warmed up i only get 12 like i said but that has been since day one.
LOL, i hear you about the cars infront...if you could check, i would appreciate it thanks..
-Ken
'00 svt #1485/2150
Posts: 3,506 |
Ok I checked...mine kinda very's between 22 and 25...not a big diffrence....at WOT i hit 35-40 psi....hope this info helps!
Lupe
