#1018695 08/02/04 01:50 PM
I did a search and unless I searched for the wrong keywords (Oil Pressure), I didnt find anything that I was looking for.
All I really need to know, is what is our oil pressure supposed to read? Not necessarily WOT, but If I can get the stages ie... idle, normal driving and WOT that would be great..Thanks in advance for your help.
-Ken
P.S. '00SVT Contour
'00 svt #1485/2150 Precision SC6152E .63 a/r, PnP Heads, TiAL 38mm Wastegate, Blitz BOV, HKS EBC, and HKS TT, Koni's Front/Rear, 19" Centerline RPMs, SPEC Stage 5 Clutch and Flywheel, DMD, Intrax, LoTek w/ Water Temp, Oil Press., EGT, Boost Gauge
#1018696 08/02/04 02:46 PM
haynes says oil pressure at 1500 rpm(hot) should be between 20-45 psi
98.5 Black SE ATX S&B filter, SVT MAF, optimized SVT TB, mesh grille, removed orange reflectors, painted rear reflector, gutted pre-cats, optimized SVT LIM, 19lb injectors, resonator removed cant afford an svt but lookin for 1 in nc
#1018697 08/02/04 03:21 PM
BETWEEN!?
That large of a range isnt a problem? That sounds quite retarded to me, but ok.
-Ken
#1018698 08/02/04 06:12 PM
Well it also depends where you take the messurements.
25 psi is adverage in the heads i have come to find out...but for a more accurate readings you want it in the block i believe its behind the bracket for the ac compressor or the alternator...from what i understand from there psi is between 40 and 45.
weight of oil your using is also a factor a higher weight will raser oil pressure.
the numbers i have given you are with 5w 30 weight.
Lupe
#1018699 08/02/04 06:32 PM
so your saying by the egr area should be 25psi then correct?
-Ken
#1018700 08/02/04 06:41 PM
Yes, i taped my Oil pressure sensor in the rear head, under the EGR. im reading 25 PSI when warmed up at idle.
Mobil 1 5w 30 is what i use.
Lupe
EDIT:::: Mind you, this is not the most acurate place to get a reading, as oil starvation issues happen in the pan...best place to put it is int he block itself...you get the most accurate and fastest readings.
Lupe
#1018701 08/02/04 08:26 PM
ok, so 25psi idle..hmmm, i have never since day one had anything greater than 12psi on idle...im confused now...well what is your psi driving and at wot.
-Ken
#1018702 08/02/04 08:32 PM
WOT honestly im not sure...never really paid attention to it at WOT..more worried about cars in front of me....i will double check the 25 psi at idle....but im pretty sure thats it.
Lupe
#1018703 08/02/04 08:33 PM
ok, even w/ my 160tstat and the car fully warmed up i only get 12 like i said but that has been since day one.
LOL, i hear you about the cars infront...if you could check, i would appreciate it thanks..
-Ken
#1018704 08/02/04 10:36 PM
Ok I checked...mine kinda very's between 22 and 25...not a big diffrence....at WOT i hit 35-40 psi....hope this info helps!
Lupe
