Posts: 382 |
my ECU code is KPL0 and i heard that there are chips code named KPL1 and KPL2 which one of these chips are better for my car? or is there a chip code # KPL0?
Thanks, Robert
Mods- SVT Kit, SVT Dual Exhaust, SVT Struts & Eibach's, H.I.D's, CTA Intake, Hightowered headlamps.
My 'Tour
Car Club- www.HiProfileCc.com
Posts: 21,653 |
Noone is gonna know what is better, actually you probably wouldn't notice a difference between any of them. Just contact a chip programmer such as KKM and ask if they can program a chip to KPL0 and if not, ask if they can do one for one of those other codes.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 2,483 |
Don't bother with a chip until you're finished doing mods. Then have it programmed for your car. You're not going to notice the difference between stock ECU and an off the shelf program chip.
Unless you have an ATX and just want it to firm up the shifts.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
Posts: 217 |
I've been pondering this issue as well. With a cold-air intake, resonator removed, hi-flow catalytic converter, and performance muffler, and recently having the engine decarbonized, how would I go about recording specs to tell a chip programmer so I could have the chip programmed to take full advantage of these mods..?
Do I need special equipment? What am I looking for? Where can I go?
Posts: 21,653 |
You go to a dyno and get a/f readings while on the dyno.
98.5 SVT
Posts: 217 |
Dyno...? What is a Dyno, and where could I go to find one...?
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by SleeperZ: Don't bother with a chip until you're finished doing mods. Then have it programmed for your car. You're not going to notice the difference between stock ECU and an off the shelf program chip.
What he said....I am spending way too much money on different chips!
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 382 |
i have an atx and the only perform ance i plan on doing is CTA Hot Air Intake  SVT Dual exhaust with out the resonator (in my garage) and maybe an under drive pulley. the rest is maintenance like plugs n wires and coil.
My 'Tour
Posts: 2,483 |
Originally posted by LoCoZ: Originally posted by SleeperZ: Don't bother with a chip until you're finished doing mods. Then have it programmed for your car. You're not going to notice the difference between stock ECU and an off the shelf program chip.
Yeah, you don't want to have to do another chip so you should just give me the S/C.
Posts: 389 |
dynometer - it measures horsepower mainly. I have no clue how much they costs, but i can tell you that if u are considering purchasing a dyno for your contour, use the money to buy a Csvt or a mustang lol. You would most likely search online for a race track (?-?-?) or some other kind of auto place that lets you run on their dyno. I dont think anyone has their own. Well there are some small scale dynos that aren't as accurate i believe. Try searching the web.
TPC
Northville, MI
2002 - Pitch Black Focus SVT (Red Trim)
Steeda Short Ram Intake
5% Tint All Around
98 Contour SE Zetec ATX - *RIP* @ Charity Motors
