p3dr02 Offline OP
Recently i checked the VCt solenoid ohms were between 3 and six so it was fine but now i checked so other sensors and after that disconnected them and started up the car. It seemed to idle better but still not sounding good i need to know what these sensors are. I know this is not my engine just thats its really clean so easy to find and display thngs
O
O
The brass fitting is a coolant sensor. That won't screw up your idle. The secong thing looks like it is pointing under your exhaust header. That looks like your PCV valve and hose. THAT will mess up your idle if it had gone out or there is a leak.
Have your tried the idle reset yet?
Disconnect your negative battery terminal from your battery and then pull your ECM fuse, (think number 12, not sure now) and leave it for 15 minutes. Come back, plug fuse back in and reconnect your battery. Drive your car like so..
Start it and run it for a few minutes in park. Now put car in drive and leave it for a minute. Now drive around at various speeds. Do stop and go. Don't forget about highway driving also. This should all take about 20-30 minutes.
Your computer should re-learn the fuel curve and stuff like that. That may help.
95 Mystique GS Zetec ATX: Dead - Dec 5th, 2003 94 Accord LX 2.2L MTX Non-Vtec. Few bolt ons. 02 Escape XLT 3.0 V6 ATX. This thing has the CD4E in it?! What the hell was ford thinking?
