#101528 07/17/01 05:21 PM
MCJ777 Offline OP
I have a 96 contour 2.5 v6 atx. I was wondering if I was to use the svt contour upper and lower intake manifold do i have to change any other parts like throttle body or using the the svt injectors or could i use the same parts? Also, how much increase in hp and torque will i gain by doing these 2 items alone?
#101529 07/17/01 06:47 PM
Administrator
Administrator
The SVT injectors will not work unless you get a new MAF calibrated for 19lb injectors, or have a chip custom burned for them.
The fuel rail is different starting in 1998, so I don't know if that will work with your 1996 without some modifications.
The throttle body does not have to be changed, but for the upper/lower to do their job, you'll want the bigger TB. The TPS sensor connector changed in 1998, so you'll have to figure that out. You'll also need a new throttle cable and bracket for the cable in order for the TB to work.
-Lance
Lance Kinley
CEG Webmaster
95SE, "Official CEG Beater"
Quaife, SVT parts, ST200 wheels, SS Y-pipe
I perceive you to be a stand-up, rational individual...
#101530 07/17/01 06:56 PM
I fitted the SVT upper intake to my std lower. Fit the SVT TB or you will be wasting your time. Bill Jenkins can supply all the parts.
5 Dr, 2.5 V6 Ghia X, 1999
Modifications:-
Inventor of the inductive Secondary monitor
Chrome grill
JR cone air filter
Black Diamond cross-drilled & grooved discs with Predator pads,
ST200 throttle body, upper and lower extrude-honed intake manifolds
Scorpion s/steel exhaust
Current Project.. Building a ST200 powered MKI
paullorman@btopenworld.com
