Posts: 1,505 |
hi i have a 2000 contour se zetec engine type. anyways my blower switch only works on high is there a warentee on this? last when i called the dealer said if its the switch it's free but if not just to look at it gonna cost me 80 bucks. so i wonder if it's worth it just to buy the switch for 10 dollars? any sudjestions?? thanks ceger's
1999 Ford Contour SE Zetec with 137k miles.
AIM Name: ContourAlf
Yahoo IM: Contour_Freak
Posts: 9 |
For $8 and ten minutes of your time, you can change the switch yourself. I think there's info on the website. I just changed mine last month.
Marvin Stockman
Posts: 888 |
i got a 96 contour. my heater/ and a/c blower switch only worked in the fast speed due to the dial not turning... took it apart and found that a ball bearing fell out of place and into a grove inside the switch and it was toast.. cost about $14.00 at the ford dealer for me.. but if you switch moves then it might be the resistor pack where the resistor wires for the slower speeds are burned and broken so they dont work, and it only works via going through the solid wire for the fast speed.. you might have a burned resistor pack???? either way if your car is still in the warranty stage you should not have to pay for either as they are both covered..
Posts: 4,051 |
What does it mean when the heat only worked on high, twice??
I was driving and had the heat on high, switched it to the next lower setting and it shut off. No other settings worked, but within 15 mins, it worked fine again.
This happened 2 different times and worked fine within 15 mins and no problems since.
I haven't seen anyone post this same problem before so thats why I ask.
Posts: 7,117 |
Search for resistor pack in common problems, you answers lie there.
Posts: 7,117 |
Originally posted by CSVT1214: What does it mean when the heat only worked on high, twice??
your problem is likely the switch, but check the FAQ section for common problems and check out the resistor pack thingy. You can inspect it to see if it's burning up.
Posts: 13 |
Haha
Mine works on all settings except high. I really don't care though as High is too High for my comfort zone anyway.
Posts: 1,241 |
Jake
96 T-Red SE V6
Posts: 9,442 |
 This is most likely your problem if the heater only works on high.
Posts: 1,241 |
Originally posted by Bk4293: This is most likely your problem if the heater only works on high.
do you think that would be the same problem if it was working on all but high?
Jake
96 T-Red SE V6
