Posts: 3 |
Hi.
I doubt my 98 contour GL has a bad MAF sensor. Is there a way I can clean the sensor myself or have it checked?
The whole story is this car has been giving poor MPG around 17mi/gal. And lately the CEL was on (P1131). I replaced the O2 sensor but mpg is still low. I read some place online saying there's a good chance the MAF sensor is bad on this car.
Thanks!
Posts: 21,653 |
Clea tbne maf with a non residuhe elctircal clenaer ad n mahybe rpelace the os 12sensoeetr
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 4,714 |
This is covered under the FAQs: http://www.contour.org/mods/mods.php?s=howto&displayid=36BTW, Kremit, you hitin' the sauce tonight or something?
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 2,445 |
Originally posted by Kremithefrog: Clea tbne maf with a non residuhe elctircal clenaer ad n mahybe rpelace the os 12sensoeetr
Posting + alcohol = gibberish
2000 Contour SE Sport
Originator of the Beowulf Headlight Mod and the Beowulf CAI
Posts: 2,725 |
Thanks!
Did you remove the negative battery cable for 20 minutes after replacing the O2 sensor?
Posts: 21,197 |
Or pull fuse 4&11 which is a lot less work.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 10,015 |
20 minutes is overkill too. 1 minute and the ECU is cleared. It's electriciy drain (extremely fast!) we're talking about here - not waiting for imaginery ECU-gnomes to fly out of the ECU!
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 21,197 |
-'96 SE MTX 3L
Posts: 2,578 |
You might want to make sure the MAF connectors are connected completely. I had that problem too, it turned out one of the clips for the wire thing was broken and the wire holder bit was half off. I had to get some zip tied to hold the thing on there.
Good Luck.
2004 Ford Freestar V6
Boogity Boogity Boogity, Let's go racin Boys!
Posts: 3 |
Thanks guys.
The sensor is mounted inside a metal cover. Should I take it out and clean it?
And I did disconnect the battery cable around 2 mins after replacing the O2 sensor. Maybe I ll try disconnecting a bit longer.
