mounta Offline OP
Hi.
I doubt my 98 contour GL has a bad MAF sensor. Is there a way I can clean the sensor myself or have it checked?
The whole story is this car has been giving poor MPG around 17mi/gal. And lately the CEL was on (P1131). I replaced the O2 sensor but mpg is still low. I read some place online saying there's a good chance the MAF sensor is bad on this car.
Thanks!
Clea tbne maf with a non residuhe elctircal clenaer ad n mahybe rpelace the os 12sensoeetr
H
H
This is covered under the FAQs:
http://www.contour.org/mods/mods.php?s=howto&displayid=36
BTW, Kremit, you hitin' the sauce tonight or something?
Posting + alcohol = gibberish
2000 Contour SE Sport Originator of the Beowulf Headlight Mod and the Beowulf CAI
H
H
Originally posted by mounta:
Hi.
Thanks!
Did you remove the negative battery cable for 20 minutes after replacing the O2 sensor?
Or pull fuse 4&11 which is a lot less work.
20 minutes is overkill too. 1 minute and the ECU is cleared. It's electriciy drain (extremely fast!) we're talking about here - not waiting for imaginery ECU-gnomes to fly out of the ECU!
LMGDAO!
You might want to make sure the MAF connectors are connected completely. I had that problem too, it turned out one of the clips for the wire thing was broken and the wire holder bit was half off. I had to get some zip tied to hold the thing on there.
Good Luck.
2004 Ford Freestar V6 Boogity Boogity Boogity, Let's go racin Boys!
mounta Offline OP
Thanks guys.
The sensor is mounted inside a metal cover. Should I take it out and clean it?
And I did disconnect the battery cable around 2 mins after replacing the O2 sensor. Maybe I ll try disconnecting a bit longer.
