Posts: 3,237 |
Screw that a turbo seems more viable to me, and easier, yes, easier!
Posts: 32 |
Jeez, It's not like I am taking these to my bench grinder and throwing them in a car. I am working with a cam grinder and together we will get the best grind for power and streetability. I want to make the most HP I can from them so that they will be a good HP per $ buy. The cams I am having made will be used on Ported heads, which means if you put them on stock heads they will still make a good bit more power but not as much with Ported heads. And that is they way it should be. Yes you can change other things by grinding the base circle such as lift, and ramp speed and such. I will be talking to my grinder this week and I will let you know. oh yeah...how do you figure a turbo to be more viable and easier? Just curious
Shawn Pasley Innovative Perfromance Technologies
92 SHO red/grey int. Slightly modified ;o)
Posts: 3,562 |
Shawn, please find out for me what cams would cost for the Duratec, I have a spare set that needs some tinkering. bnmotorsports@msn.com Also, do they do any sort of hardfacing to not reduce the base circle if that becomes a problem?
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 1,028 |
I have a set of 95 SE cams that I would like to get reground as well. Shawn, drop me a note, carsla@optonline.net and when you're ready let me know.
Chris NJ 98.5 SVT Silver Frost w/Frankentrans carsla AT optonline DOT net
Posts: 32 |
ok I'll give you guys an e-mail.
