Page 5 of 5 1 2 3 4 5
#101181 08/07/01 08:23 PM
Screw that a turbo seems more viable to me, and easier, yes, easier!
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
#101182 08/08/01 09:35 PM
F
F
Jeez, It's not like I am taking these to my bench grinder and throwing them in a car. I am working with a cam grinder and together we will get the best grind for power and streetability. I want to make the most HP I can from them so that they will be a good HP per $ buy.
The cams I am having made will be used on Ported heads, which means if you put them on stock heads they will still make a good bit more power but not as much with Ported heads. And that is they way it should be. Yes you can change other things by grinding the base circle such as lift, and ramp speed and such.
I will be talking to my grinder this week and I will let you know.
oh yeah...how do you figure a turbo to be more viable and easier? Just curious smile
Shawn Pasley
Innovative Perfromance Technologies
92 SHO red/grey int.
Slightly modified ;o)
#101183 08/08/01 09:44 PM
Shawn, please find out for me what cams would cost for the Duratec, I have a spare set that needs some tinkering. bnmotorsports@msn.com Also, do they do any sort of hardfacing to not reduce the base circle if that becomes a problem?
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
#101184 08/09/01 12:08 AM
I have a set of 95 SE cams that I would like to get reground as well. Shawn, drop me a note, carsla@optonline.net and when you're ready let me know.
Chris
NJ
98.5 SVT Silver Frost w/Frankentrans
carsla AT optonline DOT net
#101185 08/13/01 04:32 PM
F
F
ok I'll give you guys an e-mail.
Shawn Pasley
