Posts: 139 |
ok.. i baught a oem cf hood from livinsvt..... it is a nice hood, lines up nice and everything, but i cannot get it to latch down... do i have to modify the hood latch if so.. what do i need to do???
also, the plastic around the HVAC.. does that just pop out, i have the white overlays, but im afraid to pull too hard and crack the plastic or whatever?? thanks a lot for the help!!
Posts: 411 |
First, let the hood-latch "catch" on the lock. Then, with your palm directly over where the latch is, shove that summbitch down hard.
-Chuck Dienzo
Black 98.5 E1 SVT
#5022 of 6535
Born on March 16, 1998
"If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason."
Posts: 3,506 |
Originally posted by vudusvt: First, let the hood-latch "catch" on the lock. Then, with your palm directly over where the latch is, shove that summbitch down hard.
A better way to do it to, is to apply firm and steady pressure like your give some one CPR...let the latch catch, and then do that.
Lupe
Posts: 5,600 |
Black 1998.5 CSVT
Posts: 3,506 |
Originally posted by KingpinSVT: hood pins?
just thinking that....
Lupe
Posts: 2,446 |
what he said
Posts: 139 |
the thing is though, it isnt even catching the latch....the latch is like 1/2 inch forward toward the front of the hood, and it doesnt really look like it is even hitting the latch
Posts: 3,506 |
The small bolts on each side of the hood, that hold the hood to the car, losen them...you can actualy do slight adjustments with them lose...but it takes 2 people to do....i found this out when i put a fiberglass hood on.....it was off center....i losten the bolts that connect the hood, and moved it down slightly...and it fit perfectly.
Lupe
Posts: 5,975 |
I have not seen the fitment of the livinsvt hood, but with the previous OEM CF hood, buyers had to remove the hood latch and dremel the holes (not the latch itself) to move the hood latch up so it catches the hood.
Go with Roz's suggestion and try loosening it first. If that doesn't work, you'll have to remove it, dremel and fit.
HTH
Posts: 21,653 |
Loosen the bolts and move the hood so it will latch, also move the latch (doesn't move much, but it helps to move it). You should also turn the hood bump stops all the way down and maybe even cut them some. Then it's not gonna line up perfect with the fenders, loosen the fenders and move them.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
