Posts: 5 |
Well finally got the car back from the ford dealer. They checked the VCT and said all was ok. The lack of power and misfires I got came from a slipped timing belt. Lesson learned. It's kind of stupid that a timing belt wont last past 90K. But I'd suggest following the Ford rec and replacing it at 60 or is it 80K. I've been using Rotella T 5-40 Synthetic in this engine and it's so clean that I doubted the VCT could have been fouled by dirty oil. Thanks guys for all your input to my original post that started this whole thread. Your the best. Now it's time to do some more preventive matainence - I wanna drive this car till the wheels fall off.  Thanks agian, TD
99 Blue Contour
Automatic
Posts: 2,974 |
Originally posted by tommydee: Well finally got the car back from the ford dealer. They checked the VCT and said all was ok. The lack of power and misfires I got came from a slipped timing belt. Lesson learned. It's kind of stupid that a timing belt wont last past 90K. But I'd suggest following the Ford rec and replacing it at 60 or is it 80K. I've been using Rotella T 5-40 Synthetic in this engine and it's so clean that I doubted the VCT could have been fouled by dirty oil. Thanks guys for all your input to my original post that started this whole thread. Your the best. Now it's time to do some more preventive matainence - I wanna drive this car till the wheels fall off.
Thanks agian, TD
I'm still on my orignial timing belt and I have 240,000km on my car , mabye my loss of power is comming from the timing belt eventho my VCT tested at 9ohms.
Aaron
AKA NVS SVT
98.5 Silver/Blue SVT#4553
Yeah it's modded
98 T-Red/Blue SVT Contour Totaled 06/05/06
03 3L,VCN 2000,CAT Cams,MSDS Headers w/Y-Pipe,XCal2 and lots more
Posts: 795 |
Aaron
NVS: i changed mine at 150 000 kms ( i think around there anyways) and it was cracked and barely had any teeth left, you should probably get it changed or atleast checked out, i think that you have to change at around 80 000 kms
- Eric
previous:
'98 contour sport
zetec mtx
light prairie tan
Posts: 2,974 |
Aaron
Here is the funny part, I got it checked at 220,000km and the guy was shokced because when he took it off he said it wasn't stretched and it looked like it was brand new and that puzzled him. BUt now that I got my Unothodox Racing cam gear(thanks to Chris from CTA) I will go get my timing belt belt repelced Anyone know how many degrees I can advance the timing on it?
Aaron
AKA NVS SVT
Yeah it's modded
Posts: 21,653 |
I think advancing past 5 degrees isn't gonna help you any. I don't think you'll do damage with full advance, but it won't run good. I would just try two or three degrees of advance. You need another cam gear though,, too bad about that VCT crap.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 2,974 |
Thanks for the info, and yes it is too bad that I have VCT.
Aaron
AKA NVS SVT
Yeah it's modded
Posts: 22 |
i can tellyou here in the great land of the USof a it cost me 600.00 to have it replaced not 27$ and some odd change. that might be what the connector costs but not the solenoid. nobody is going to tear into your motor and remove the cam to get the VCT solenoid off and only charge 27.00. not at 75.00 per hr. labor. and they had my car for three days. the solenoid alone costs close to 300.00. and you can only get it from FORD.
Posts: 937 |
Is there a site online that sells the VCT solenoid?
Posts: 5,143 |
dont use Champion Double Plats... I put then in my Zetec, they were great for about a week, then I was getting onto the expressway, Floored it... Shifted to 5th gear.. and I got misfires like CRAZY. I had cracked one of the plugs... Head over to autozone, get Motorcraft part number 417FE spark plugs... or Autolite Double Platinums... I had the Autolites, and I got misfires also. but thats only in a rare case for a zetec. Once I went to the motorcrafts I have smooth sailing.
Sorry if im going to sound like a n00b right now... but what does the VCT do exactly? I know it was on the Zetec after 98+ (right?)
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by TronX: Is there a site online that sells the VCT solenoid?
Not really....but the dealer around here wants nearly $300! I need to search the junkyards soon!
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
