I'm sure that the HOT under hood temps were causing my 'tour to run like crap. I guess that if you lived someplace where the temp never got over 50 degrees, a short ram intake would work just fine.
I'm also sure that if I just threw an air filter on the MAF (like the CTA), that all of the problems that I had would return. Which brings me to another idea that I had...
You could keep the stock air box, modify the fender tubing, drop in a K&N panel filter, and use tubing similar to mine. This would probably net you a budget CAI. With parts from overboost.com, it could be done for around $150.
I'm sorry guys buy I have no desire to produce these. The parts already cost soo much that it wouldn't be worth it. That is why I posted all of the pictures and the sources.
DIY.
Later,
Ben
