Page 3 of 6 1 2 3 4 5 6
Originally posted by madmole:
Dont want to spoil anyones fun, but looking at Roars web site it looks awfully like inside the carbon fibre lookalike outside its just a couple of sponge filters.
Anyway on the Mondeo the Filter is not the bottle neck in air supply, its actually all those resonaters and pipes behind it. K&N, KKM, Roar or even no filter will give you at max 2hp and more noise than standard. I see no dyno difference between K&N and no filter on mine (lots more noise though)
The only way an air filter swap will ever give you more than 5hp is if you have modified everything else and the air filter is limiting the flow, this just isn't the case on the Mondeo (whoops Contique/SVT etc)
I've been doing a lot of intake work on my Mondeo, using a Dyno, and moding the filter and TB have not made more than 2bhp's difference, the intake path is the problem and gives very turbulent flow, we need to smooth this flow to get velocity up and make it longer.
By the way, Larger TB's have always given me less power as the volume of air through the intake manifold is the restriction, hence wider TB, same air flow = lower air speed
Just my 2 pence worth
I agree completely!
Have you tried a Monster Flow filter? They claim to do exactly what you are stating, smooth the flow of air and reduce turbulance. Let me know what the results are if you try.
Peace
Justin
1998 Black SVT
jcboeckl@unity.ncsu.edu
Originally posted by QUICKSILVER:
I just RACED a new Camaro Z28 which had an exhaust that was loud as hell, had all kinds of gauges in his car, and although he got a jump on me I ended up beating him in the end thanks to the wide turn on the freeway and the Roar, which than I flew past him going about 130MPH. He didn't have a chance after that, so he gave up, he even beeped his horn later down the road congratulating me, damn he must have been "SHOCKED AS HELL!"
I'm sorry...I must have mis-read. Z28?
I'll grant the curve, but flying by him at 130mph?
Brinn Riley
Melbourne, FL
'00 Black/Tan SVT Contour #560
As a friendly reminder, even a new convertible automatic Z28 runs high 13's in the 1/4 mile and tops out a few ticks shy of 160mph.
Brinn Riley
Melbourne, FL
The Mockery!!!
You Guy's are partly right and very funny. First, Yes the Z28 would run over me if the stretch was long enough, but it wasn't and that's why I was able to beat him. The bend on the Freeway is not a sharp bend but you do go from heading West to straight North just from that bend, and although I didn't know how fast I was going around it because I was focused on the road, I did have 2 of my Bros in the car as well and they were watching the gauges. I passed the Camaro pretty quickly around that bend, and his car was screaming, but he probably couldn't push it like I could. The answer is "YES" I was going 130 around the bend, it's as simple as that. Oh by the way I do have 17"SSR's on my car so if my gauge was saying around 130 than I probably was actually going faster than that, come to think about it.......
Just to let you folks know I'm not your everyday wannabe racer, I am a RACER, and RACE is what I do, Solo 1 & 2 that is.
SVTimulate If anyone knows there cars it's me, so don't worry about it being a V6, because a Z28 is what it is.......
I have no 1/4 mile ET's cause I'm not much of a drag racer, to boring, but I will say that I will beat my friends 230hp Audi TT, which has an upgraded exhaust and lowered....
"ALOHA, MALAMA PONO" wink
Performance Xpress Racing
Silverbulitt@msn.com
Our websit www.PXRacing.com is coming soon!!
We carry Contour/Cougar parts for the 2.5 Duratech and 2.0 Zetec
...moding the filter and TB have not made more than 2bhp's difference, the intake path is the problem and gives very turbulent flow, we need to smooth this flow to get velocity up and make it longer.
Are you talking about Zetecs here? If so, what in your opinion is the one thing someone should do with a Zetec intake?
Personally I find it hard to believe that new filters won't help, given how numerous the positive testimonials for different filters have been.
96 GL Zetec ATX, white with pinstripe, nickname " Sam Smooth "
mods so far: CTA intake with homemade heat shield, KVR drilled front rotors & carbon pads w/ 500° fluid
planned mods: exhaust (want to keep it quiet), e-ram (awaiting installation), diablo chip
involuntary mods: compression increased after head gasket failure
OK Guys let's put it this way, first it's leap and bounds ahead of the KKM and look alikes, beleive me, but it will cost you. Second, there is an application for the SVT.
I have the KKM but I no longer use it because why would I won't to drop down to something less worthy. Anyone want to buy my KKM. Anyways I've got the minny blower but I haven't installed it yet need to do some fabricating first. But I did test it and the damn thing blows like a MUTHA FUC*A.
The great thing about this intake is that it performs better than the KKM in the low range and the mid and screams like you wouldn't believe in the high end, which explains it's high breathing characteristics. This intake will be a plus if you do a complete exhaust upgrade which I will be doing very soon and changing the MAF and TB.......YOU DECIDE!!!! wink
This post is a bunch of @#*T...get a life man...and enjoy the roar lol
Big gulps huh? Welp, see ya later
I'm not even sorry for saying this... smile but Quicksilver, you're a liar.
Uhh you're going to beat an AUDI AWD TT? I'd have to see this...
98 V6 Lots-o-mods SOLD
88 Daytona Shelby Z TII (The beast)
87 Daytona Shelby Z TII (Holy 20 psi of boost batman!)
Mods- 3" Downpipe, Hi-Flow cat, 3" mandrel bent exhaust with Dynomax Ultra flow. Manual boost controller, TurboXS blowoff, 5th injector, large canister wastegate, Nitrous Express go-fast-be-happy kit, ported exhaust manifold, ported intake manifold, upgraded motormounts, eibach springs, strut tower brace. Oh and 20 PSI to boot.. my oh my...
Well I told my Friends that were with me that no buddy believed on the Contour forum, a site they have no clue about, while we were heading to work yesterday, they said what the FUC@ is up with that. I told'em that's the way it is ONLINE.
Burnt...NUTS, JC Aim.....LOWER and SER....GIRL aint that the great thing about the internet, you can call someone a liar and don't worry about anything. I tell you guys what, E-mail me, come to Hawaii and this Hawaiian will drag your ASS all ova the FUC*IN road just for saying that ****, than while you're lying there, I'll show you what I mean by beating a Z28 as well as my friends Audi TT........ALOHA NO', HELE MAI... mad
why would you waste time typing that? no one is going to hawaii, so that is the most pointless thing i have everhead. if you like your roar, great. if you other guys dont, great. just drop it, this is going no where. someone grow up confused
andy watson on my 'Beer Goggle' Post:
AureiusX: You needlessly made an ass of yourself
JenovaFire: it was a good idea at the time
AureiusX: LOL
AureiusX: so was she
