Posts: 1,399 |
Sometimes when i hit the brakes, I get a lot of kickbabck and vibration, like the ABS is kicking in. The problem is I am not in a situation where the ABS should be kicking in. I am usually stopping at a light very sedately. Am I looking at trouble here?
98 Silver Frost SVT
97 BMW 540I Sport, six speed
"Blue is for sky, black is for soil, and white is for simplicity, purity and hope for the future"
"A coveted car should never stunt your life, but should make it more rich and interesting."
Posts: 10,015 |
Are you saying it only happens under light braking, or that you typically use only a little pedal force?
Sometimes, too light of a brakin technique will cause the pads material to deposit itself onto the rotors. This can be remedied by removing the rotors and scuffing them back with some emery cloth.
Therwise is it's shakin the steering wheel considerably, your rotors may be at the end of their life, and have started warping due to reduced thickness and consequent inability for them to disipate heat quick enough, resulting in warping.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 1,399 |
Usually it is under light braking, although it has happened once under harder braking. Pads and rotors are a year old, and I re-torque my bolts personally with a torque wrench if the wheels ever come off.
98 Silver Frost SVT
Posts: 2,725 |
Originally posted by Stazi the Aussie: Are you saying it only happens under light braking, or that you typically use only a little pedal force?
Seriously my pulsation is almost gone after I did some heavy braking. It seems under 30 while braking and only for a second to two I get a pulsation.
I dont have to remove the damn caliper and stuff I could actually just scrub them while there on there?
Posts: 103 |
Does it feel like a bad rotor or like the ABS is kicking in. You mentioned it felt like ABS in your first post. Just trying to figure out which problem we're chasing, and ABS problem or a rotor problem
Posts: 1,399 |
It feels like the ABS is kicking in.
98 Silver Frost SVT
