#1007883 07/19/04 04:28 PM
sugazzi Offline OP
I just bought another Contour so that I can switch the engines. They're both '95's. I've swapped engines before although these Contours look like you can pull the entire drivetrain out from the bottom. Has anyone here pulled the engines up from the top? Hopefully it's not to much trouble to do since I don't really have a way to pull the drivetrain out from bottom. Anybody that's done this and has any suggestions, please reply. Thanks!
#1007884 07/21/04 03:02 AM
F
F
I've done quite a few engines in these cars and it definitly has to be removed from the bottom. It actually isn't as bad as it sounds because it all comes out together with the cradle. If you plan ahead you can have it all out in a couple of hours(OK add an extra hour or two if you've never done one before). I've tried to pull one from the top(it was a 5spd which has a little more room), but by the time you unhook everything and try to wiggle the engine out the top, you could've had the whole assembly out from the bottom. I think the Haynes manual even tells you how to remove it from the bottom. Of course for me it is no big deal because I used to do a lot of Fiero engines and they came out the bottom also.
All you need is a floor jack, jack stands and an engine hoist. all of which you should have anyway for an engine swap.
Just be glad it's a Zetec and not a Duratec!
Parting out 95-97 Contours/Mystiques. Contact me directly at ALFIGOLS@yahoo.com if you're looking for a particular part.
