Page 3 of 5 1 2 3 4 5
#100748 07/09/01 07:09 PM
Very nice Mark..
Would it be worth building an airbox for your K&N with some big bore cool air ducting? Perhaps dropping IAT maybe 10-20 degrees?? Every little bit might help.
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
#100749 07/09/01 07:12 PM
W
W
The biggest thing is getting a larger filter on there. Brad Noon showed me how he did it on his at SZ so as soon as K&N sends me the correct filter that I ordered I will get that installed.
I will say however, that there are plans in the works to completely change the supercharger intake to get cooler air and more of it.
-Mark
You can do something for Love...
You can do something for Money...
But there is nothing quite so satisfying as doing something out of Spite.
GTExtreme1@aol.com
#100750 07/09/01 09:16 PM
Good set up Mark and just to add info...Most of these systems were around in the 70's when we all wanted 12:1 CR's!!!At that time washer motors were used and a 'throttle kicker' electric switch.Another spin off is 'steam' injection where the water is fed through copper heating coils around the exhaust manifold(s),does the same job but with superheated steam/water vapour.On a 'stock' vehicle either system would let you run with more ignition advance and give more power.Most of the 70's set ups could run 6-10 degrees more max advance than stock without any det...just my 10 cents! Regards TAH
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#100751 07/09/01 09:36 PM
F
F
Leave it to Terry to give more than 2 cents wink
Best Regards,
Trevor Cole
New Edge Cougar Forums
#100752 07/10/01 01:59 AM
Sweet setup!, whats a MSD box?
5 speed MTX /KKM Custom Intake /Dynomax Super Turbo /TH Fix /Audi A6 Sidemarkers / Badgeless /Audio:(JBL600.1 amp,Polk Dx Subs, Infinity 6953i 6x9's, Lightning Audio Strike Cap)
#100753 07/10/01 02:31 AM
Originally posted by bret:
i know someone who does... priv msg me...
Bret,
Would the initials be TP?
Mark
#100754 07/10/01 02:36 AM
TP?
#100755 07/10/01 04:09 AM
i want one for the reasons terry just discribed but everyone on here says its forced induction only. I want it for the timing advance I run 104 in my jetski because of new pistons but would like to do somthing like this for it too so I wouldn't have to go to the airport with a 50gallon drum and pay out the ass every month give or take a week.
98 silver frost SVT
custom built intake, offroad y-pipe,mystery mod,remote optimizer,short shifter,zex nitrous, lots of stereo, 17 konigs
with paradas.(bent) TOTALED do to freak electrical fire?(that started at a wireing harness ford neglected to tell me should have been recalled as they did with the 95se) I miss this car.
NEW PROFFESSION AS A TROLL.
new car. 2000 dodge dakota 4.7l v8. custombuilt intake, custom exhaust, kennebell pcm, and electric fan conversion, 180 stat, 3.55 pegleg, my old stereo system, 17x7 billets and 255-50 nitto 450 tires. next drop and traction adders. g-tech 14.5
in search of 95 se fivespeed to hang contourparts on.
#100756 07/10/01 07:46 AM
It's an ignition system. I believe http://www.spmotorsports.com carries it. Isn't that system adjustable some how, I forget.
BTW, the engine bay looks great and that system is sweet. Good Luck. laugh
#100757 07/10/01 01:58 PM
F
F
According to these people, it is done for fuel milage and more HP/TQ: AquaTune ... they have a 25% increase in fuel economy GAURENTEE. Only down side to their system is that it is pre set to your car's engine size, and is non adjustable.
Best Regards,
Trevor Cole
