Posts: 1,346 |
i would say you stand a chance....from what i have been around STOCK GSX=awd are only good for high 14's and the FWD GS-t will not harm an svt
know from experience
E1 CSVT
s/c-----x
turbo---x
3L------check
Posts: 3,840 |
Originally posted by incubusjunkie614: i would say you stand a chance....from what i have been around STOCK GSX=awd are only good for high 14's and the FWD GS-t will not harm an svt
I want what you're on, because an Eclipse GST would walk almost every CSVT here. Sorry guy, but you don't stand a chance. The only thing you'll probably remember about this race is his license plate number.
Troll. 1997 VW Jetta MkIII GLS 5spd
All hail my appearance on CEG!
Posts: 9,065 |
Originally posted by SAV-ZX2: Originally posted by incubusjunkie614: i would say you stand a chance....from what i have been around STOCK GSX=awd are only good for high 14's and the FWD GS-t will not harm an svt
From a roll I took a GS-T...but it was missing the T...
Posts: 9,602 |
The GS-T's are faster then the much heavier GSX's in stock or near stock form.
I also want some of what you are smokin' It must be great...
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,303 |
Originally posted by DemonSVT: Originally posted by incubusjunkie614: i would say you stand a chance....from what i have been around STOCK GSX=awd are only good for high 14's and the FWD GS-t will not harm an svt
I do believe the GSX's are acutally faster, atleast that is what experience and stock 1/4 mile times lead me to believe. Also depending on the year of GSX or GST you meet up with you may or may not be able to beat them. The 95 GST and GSX run damn near similar in 1/4 mile times, hovering around 14.9 to 15.0 (95 being their fastest year from the factory). Now I believe that is faster than our cars, easily, but its close enough (i believe most people get mid to low 15's with their lightly modded svt's) to possibly be a drivers race. With that said most GST's and GSX's you come up against wont be stock. It is too easy to add a boost controller or anything like that to just beef up their cars.
Goonz12: <---tries on mommy's cloths
Posts: 3,840 |
Originally posted by DopePope: Originally posted by DemonSVT: The GS-T's are faster then the much heavier GSX's in stock or near stock form.
I do believe the GSX's are acutally faster...
Certainly. If you decide that cooking your clutch is worth a tenth or two off the line that you'll lose anyway as speeds increase. GSXs carry a ton of unsprung and extra weight due to that AWD system, and they aren't making any extra power over GSTs, so any minuscule gain you'll get right out of the hole will be lost by the time you hit the lights.
Posts: 9,602 |
Originally posted by SAV-ZX2: Originally posted by DopePope: Originally posted by DemonSVT: The GS-T's are faster then the much heavier GSX's in stock or near stock form.
See that's just it. The AWD ability gain is small because the stock or near stock power can not sustain wheel spin and the engine bogs badly.
Also it has almost twice the powerloss through the drivetrain.
Stock for stock the GS-T is a hair quicker (1-2 tenths) but several mph faster. The AWD system is nothing but a large burden after the first 60'
Now on a moderately modified or better DSM it changes everything because then traction is king verses less weight and parasitic drag.
2000 SVT #674
Posts: 349 |
Originally posted by DemonSVT: Now on a moderately modified or better DSM it changes everything because then traction is king verses less weight and parasitic drag.
Agree 100%. I wish you could all go for a ride in my friends gsx. Its ridiculous
Posts: 1,303 |
I've yet to go up against a stock GST or GSX, its so rediculously easy to make those things just balls out faster. I will still maintain though that if you are going up versus a pre 95 gst you should have them if you are a better driver. But then again i just reread your post and saw it was a 98... so... hopefully he sucks
Posts: 101 |
Originally posted by DopePope: I've yet to go up against a stock GST or GSX, its so rediculously easy to make those things just balls out faster. I will still maintain though that if you are going up versus a pre 95 gst you should have them if you are a better driver. But then again i just reread your post and saw it was a 98... so... hopefully he sucks
Why? They use the same 4G63 motor, in which, the pre 92 1/2s actually use a stronger version of that motor.
