Page 1 of 5 1 2 3 4 5
#100728 07/09/01 01:59 AM
W
W
Ok...
I have been working w/ Aussie SVT on this project for the past month or two. I was able to meet up with him this past friday and start the install process, all of the plumbing has been done and installed. All that is left is the wiring of the computer and harness.
The water injection system is more then just a pressurized water sprayer dumping water into your engine... the key word is "system." Every aspect of the system is computer controlled and fully adjustable. the computer senses ambient outside air temp & the temp of your superchargers (or turbo) discharge temp. so it knows when to turn itself on. it also senses your engines duty cycle and will come on under WOT.
As my fellow SC owners know, discharge temp can approach 200 degrees F. and as the temp gets hotter the power decreases considerably. The Water Injection works liek an intercooler... only with a little more punch.
Here are a few pictures:
my engine bay (Water Injection lines are yellow):
Here is a shot of the dual water pumps:
Here is the actual spray nossle:
Here are a couple shots of the TB with the injector fitting installed:
Here is the water tank (1 quart JAZ Jr. Dragster fuel cell until I can aquire a little more room):
Here is the air assist line to give the tank positive pressure:
and here is the computer:
please feel free to ask questions, I will do my best to answer them.
-Mark
You can do something for Love...
You can do something for Money...
But there is nothing quite so satisfying as doing something out of Spite.
GTExtreme1@aol.com
#100729 07/09/01 02:09 AM
SWEEET!
i am offically a troll... so take my information and advice with a grain of salt.
08/15/2001 - 11/05/2001 : 1999 Ford Contour SVT : 170fwhp - 147.9 fwtq
07/17/2001 - __/__/____ : 2001 Roush Mustang GT Stage 1
11/05/2001 - __/__/____ : 2001 Ford F-150 SVT Lightning
#100730 07/09/01 02:19 AM
WOW eek
I want me one of those…
Me no understand? Water bad for fire…
How does this work?
- 1996 Mystique Spree 2.0 ATX
- 2002 Mustang GT 5-speed
- North Georgia Auto Forums
#100731 07/09/01 02:25 AM
Originally posted by burgmanSVT:
WOW eek
How does this work?
What he said, were does the water go once inside the motor, or are we talkin super fine mist. very interesting, I was looking for a way to get an intercooler in this puppy, was looking into hoodscope/intercooler unit. Let me know how this turns out, one day I may need it wink
#100732 07/09/01 02:28 AM
yes a fine mist, aeration per say - water possesses a very high amount of latent heat, which makes it ideal for cooling the combustion process. Water will improve the knock resistance of an engine, while also cooling the intake (or exhaust in a turbo) gases, thus allowing higher boost pressures, while at the same time reducing thermal stress on the combustion process. Water will also help prevent the build up of carbon deposits, and can protect the valves and valve seats from getting burnt, pitted or distorted.
Todd Christ SVT Contour Registry
MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator
'98 E0 SVT Contour #1037 of 6535
#100733 07/09/01 02:31 AM
more data -
a high pressure jet of water (about 110 - 130 psi) into the intake manifold. As the latent heat of evaporation of water is 6.5 times that of fuel (2256 versus 350), as it vaporizes in the intake manifolds it absorbs heat, thus lowering the temperature of the air/fuel mixture, and significantly reducing the chances of detonation.
I'll bet Mark's 2ndaries are nice n shiny now smile
#100734 07/09/01 03:15 AM
would this be of any benifit to someone not running with hair dryer? like oh say, higher compression?
#100735 07/09/01 03:17 AM
W
W
well, the system is unfinished... note the picture of the computer in my hand and not in the car...
all that is left is the electrical portion of the system... then it is time for tuning.
-Mark
GTExtreme1@aol.com
#100736 07/09/01 03:19 AM
W
W
no, you need the super heated discharge temps from forced induction for it to work properly.
-Mark
GTExtreme1@aol.com
#100737 07/09/01 05:30 AM
Administrator
Administrator
Would ice water in the tank and the water lines heat insulated work better? One would think superchilled water would have an even greater heat quenching affect.
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
