#1007047 07/18/04 05:28 PM
would there be any advantage in changing the single part of the svt exhaust to 2.5"? two 2.25" pipes feeding into one 2.25", seems like opening up the single part would be better also I'm going to gut the precats and install an aftermarket y-pipe, hiflow cat and magnaflow resonator, DO I NEED TO DO ANYTHING TO THE 02 SENSORS?????
#1007048 07/18/04 08:14 PM
If you gut the pre cats I believe you will need a MIL Eliminators to get rid of the CEL.
http://search.ebay.com/MIL-ELIMINATORS_W0QQsosortpropertyZ1
OR Go to www.spmotorsports.com they have them about 60 bucks
They call them O2 Enhancers on the spmotorsports site.
#1007049 07/18/04 08:21 PM
you will need a MIL eliminator if you gut the precats.
#4559 of 6535 born on Feb 17, 1998 Black 1998.5 CSVT FOR SALE [cleaning house]: SVT rear swaybar. Reasonable offer and its yours!
#1007050 07/18/04 09:48 PM
I got gutted pre-cats and didn't use a MIL eliminator. I have no CEL.
Then again, my car is a freak of nature.
The Spickle New Car: Infra Red '04 FSVT Former Car: Black '98 CSVT, #3137/6535 "The Unluckiest car.. ever"
#1007051 07/18/04 11:14 PM
will the emmissions testing be able to tell I have the mil's installed. in Md. they don't "sniff" your tail pipe they plug into something under the drivers side dash
#1007052 07/18/04 11:47 PM
I believe all that does is run a diagnostic for emission related codes but I might be wrong anyone care to shed some light on this?
#1007053 07/18/04 11:50 PM
Yes, that is the OBDII port.
99 SVTC, T-Red, #652/2760-12.8.1998 Mother#@%@!* did I sound abstract? I hope it sounded more confusin than that!
#1007054 07/18/04 11:56 PM
will it make a difference in the test?
#1007055 07/19/04 12:22 AM
You will install MIL eliminators to: REMOVE... THE... CEL... (so that the CEL will report no problems)
and you wanna know if this scanner they hook to the OBD-II port will show anything different? Put it this way: if the scanner shows something wrong, the MILS don't work (but you'd know that cause you'd have a CEL lit) Afterall, that is the POINT of the mils.. to make the OBD-II valuse look normal to the ECU
Ray
Ray
