Posts: 291 |
We have just finished the first prototype set of tubular toe control arms. They will be offered in 2 styles-1 with polyurethane bushings at each end and 1 with an adjustable spherical rod end at the knuckle. They are fabricated from high strength, seamless tube, TIG welded and weigh 1/3 less than the stock arms.
We will be track testing them next weekend. Pricing has yet to be set. The poly bushings are easily replaceable (unlike the stock arms). They will not twist or bend like the trouble prone stock stamped pieces.
Please post if you're interested so we can establish quantities & prices before doing our first production run. Digipics shortly.
Redcoat Raceworks. Performance parts and custom fabricating for Contours, Mystiques and Cougars. Specializing in chassis and suspension parts. Custom end links, control arms, strut tower bars, engine torque braces, etc.
Posts: 555 |
Posts: 1,859 |
Yes intrested. But I didn't know you guys were in buiness still. Whats the eta?
'99 Silver svt
For sale
19" Axis Neo wheels
3.0 parts, pre-98 trunk,
Check classifieds
bp.powell@comcast.net
Posts: 291 |
Yes, we're still in biz. Been trying to refocus on a limited number of products so there was some down time within the last year or so. It didn't help that my partners SVT was written off either.
The toe control arms will take 2 to 4 weeks to run off depending on how many orders and which style go. There's more labour/machining in the double poly bushed type. Forgot to mention that they're greasable with a grease fitting at each bushing.
They're also easily installed, unlike the forward rear control arms which require dropping the complete subframe to access the inner mounting nut/bolt assembly. A rear alignment IS suggested after installation.
Posts: 133 |
I'd like to know more info, but it sounds good.
2000 SVT Contour #2099
H&R Springs
Koni Struts
KKM Intake
BAT Intake Tube
Team Dynamics DTM's
Mirko splitter
carbon fiber parts
Posts: 1,101 |
Can I get a set?
Posts: 21,653 |
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 291 |
For those who'd like more info.... What can I provide/tell you? Is there a preference whether they have a spherical rod end or polyurethane at both ends? Obviously, the rod end type would be more $$$. My guess is that the double poly style will allow less twist than the rod end ones.
Let me know.
Posts: 21,653 |
What are the advantages and what is a good price estimate? Thanks.
98.5 SVT
Posts: 94 |
Interested, but it is dependant on final pricing.
Tom
'00 Cougar
'95 Mark VIII
Posts: 291 |
Advantages would be greatly improved rear suspension control and grip. Suspension members should operate in a single plane for best results. Both lateral rear suspension arms are prone to twist-I boxed the forward control arms on my car and it made a very noticeable improvement to the handling and ride. Got sick and tired of replacing the toe control arms when the bushings failed or some dope lifted my car up via the toe control arms and bent them.
Cost-wise we're looking at something like $125-135 for the double poly bushed type and $170-200 for the poly/spherical rod end type. The large variance in the second design is dependent on the type of rod end we supply (econo, w/ grease fitting, 2 piece, 3 piece or teflon lined). They will be offered at some kind of "special introductory" price with minimum quantities.
Posts: 21,653 |
Is that $125 each or for a set and how easy/hard are they to install? Thanks.
98.5 SVT
Posts: 291 |
The prices I've quoted are per pair. They're very easy to install. Raise the rear of the car, insert jack stands or wooden blocks, remove 2 nut/bolts per side and remove stock arms. Reverse procedure to install then go for a rear wheel alignment (toe adjustment).
Sound OK?
Posts: 21,653 |
98.5 SVT
Posts: 1,859 |
Intrested
'99 Silver svt
For sale
19" Axis Neo wheels
Check classifieds
Posts: 120 |
Posts: 317 |
Originally posted by LUCA: Yep.
You can be Phil too if you'd like.
Posts: 291 |
OK, the pics will be taken this weekend when I can borrow a digicam. Should be able to post them early next week. To date, the double polyurethane bushed style are all that are done. The spherical rod end type are at the welders as I speak-I'm to pick them up on Monday 7/26. I'll paint them, then take pics and post. So there will be much more info. by the middle of next week. I'll probably post the pics here and run a group buy when I'm certain they're durable and roadworthy. Stay tuned.....
Posts: 604 |
im interested once i see pics. ive been wanting to replace mine for a long time since they are like the only thing thats rusting under my car and the bushings at the pivot point in the middles are toast. seems like a good price too
Posts: 650 |
You see, I would be very interested, but I ordered something from you guys last year, and you never sent it to me. When I tried to reach you on the phone you guys never answered.
97 Zetec MTX Sport
Mk1 Mondeo Morettes & Clear corners
Full SVT kit w/ Molded Mirko Splitter, Carbon Fibre Hood
Ground Control coilovers w/ Koni adjustables, BAT anti roll bar
Pics of my rides in my profile!
Rally drivers do it sideways......
Posts: 291 |
As I mentioned earlier, we had downtime last year when we were figuring out whether to stay in business, reorganize, shut down or..... We decided to scale down the amount of items we supply and concentrate on our exclusive parts. Stuff like the Street Link, modified throttle bodies & LIM's, air inlet kits, suspension parts, etc. Anyhow, if you wish info. or to place an order email me at tech@performancefords.com. Our sales dept. can be slow to reply sometimes.
Posts: 1,859 |
Originally posted by Bradness: Our sales dept. can be slow to reply sometimes.
I think that was most peoples biggest problem with your company, let hope this time around is better
'99 Silver svt
For sale
19" Axis Neo wheels
Check classifieds
Posts: 2,779 |
I would say, in my experience, slow is an understatement. I would shoot more towards I was lucky if I got a response after a month or two. I'll give you guys the benefit of the doubt though, when I did get in contact with you guys, there weren't many hassles and Alex was always pleasant.
Bradness, PM me please. I still have a Brullen y pipe that didn't fit and been taking up space in my room. Alex emailed me a month or two ago about it, but as I said above, never responded back after that.
Posts: 2,469 |
In regards to handling. any idea how this will effect understeer/oversteer? The last thing i need is more understeer.
Posts: 9,065 |
Posts: 291 |
In terms of handling.... I'll know for sure very soon. Theoretically speaking, they will stiffen the rear as poly is stiffer than the rubber bushings that Ford uses. Therefore, they will add oversteer albeit not much.
AS the PF company techie, I ride Alex just like you guys do. Stuff sent my way will usuallly get priority-so keep the letters, faxes and emails coming!
Posts: 1,101 |
Posts: 6,760 |
Looking good!
Ryan
Trollin!
Posts: 133 |
Nice. I like to hear how they work on the track. Would like to get rid of the stock crap bars.
H&R Springs
Koni Struts
KKM Intake
BAT Intake Tube
Team Dynamics DTM's
Mirko splitter
carbon fiber parts
Posts: 217 |
I'm thinking out loud here, since the toe link is behind the rear wheel centerline and the new link is solid, thus stronger, this modification will add more understeer characteristic to the vehicle while cornering. This may result in more stable vehicle through the turns and more self-correction over bumps.
Only real-life testing will bear this out( or dispell it ) with certainty.
Posts: 127 |
Cougar V6 MTX: GMK Carbon Fiber Cold Air Intake : SVT UIM : SVT LIM : SVT TB : MSDS Headers & Ypipe : TruBendz 2.5" Borla Single Exhaust : Soild Front Motor Mount : & more
Posts: 27 |
I am in the process in upgrading my suspension right now. I'm interested but am waiting to hear how the track testing goes. Also curious what the final pricing is. Are there any after market front control arms for our cars?
Posts: 458 |
count me in i will be paying next 15th i want the better ones. ive been through 3 of these ford swing arms
Posts: 94 |
Tom
'00 Cougar
'95 Mark VIII
Posts: 4,760 |
Team Evo
Staz: You know why they call it Skunkworks?
Everyone: Why?
Staz: Because everything that comes out of it stinks!!!
Steeda-I hate you stazi
Posts: 430 |
Lee Cox
No Contours to speak of...
Posts: 4,760 |
Team Evo
Everyone: Why?
CEG road warrior
CEG road warrior
Posts: 17,248 |
This sounds interesting!
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 1,101 |
I'm in the process of accquiring another set to test at the track with rod ends at one end and a bushing at the other. The last set held up very well with the abuse of a few track days and once I have had a chance to test this style I will fill you guy in on my thoughts.
Posts: 29 |
keep me posted if i loose track.
Posts: 5,975 |
Originally posted by I-Dom-In-8: Very intrested.
Posts: 6,760 |
believe it when I see it, then I'll be interested. Originally posted by SVT PETE: Originally posted by I-Dom-In-8: Very intrested.
Ryan
Trollin!
Posts: 1,101 |
Originally posted by RTStabler51: believe it when I see it, then I'll be interested.
Look a few pages back at the pics of prototypes installed on my car. What's not to believe?
Posts: 5,975 |
Originally posted by timeless420: Originally posted by RTStabler51: believe it when I see it, then I'll be interested.
Ignore him - he's not a people person.
Posts: 21,653 |
Originally posted by SVT PETE: Originally posted by timeless420: Originally posted by RTStabler51: believe it when I see it, then I'll be interested.
LOL!
98.5 SVT
Posts: 13 |
I would be interested as well.
99 merc cougar, Auto cross junkie
Posts: 284 |
Originally posted by PaulDaJedi: I would be interested as well.
ditto
Totally sold out for a 90 GT vert.... 1/4 mile is almost the same as my modded svt w/n2o was...
Posts: 1,101 |
Posts: 9,602 |
Just one question... WHERE THE F#(% ARE MINE!!!  Looks good...
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 4,760 |
Looks good...
Team Evo
Everyone: Why?
CEG road warrior
CEG road warrior
Posts: 17,248 |
Looks good...
I like everything......but the girly "baby blue!"
Hector
257HP/259TQ
160HP/141TQ
Posts: 1,101 |
I don't think the production ones will be that color. The powder coat was supposed to be Ford Racing blue but when baked it turned out lighter
Posts: 4,760 |
Originally posted by timeless420: I don't think the production ones will be that color. The powder coat was supposed to be Ford Racing blue but when baked it turned out lighter
I would really like to see a Nice red.... Would go with my H&Rs lol
Team Evo
Everyone: Why?
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by I-Dom-In-8: Originally posted by timeless420: I don't think the production ones will be that color. The powder coat was supposed to be Ford Racing blue but when baked it turned out lighter
Red or black would be fine with me.
Hector
257HP/259TQ
160HP/141TQ
Posts: 9,065 |
I like that you zurk'd em so to speak. I'm interested!
Posts: 3,335 |
Still intrested, even if they are baby blue.
· Jon Miconi
· Coming Soon!
· 01 Cougar
· 98 V70R
Posts: 1,101 |
You guys should have an update from me around Tuesday. I'm heading to the track on Monday
Posts: 65 |
What's the deal with these. I need a set, like yesterday. My stockers are bent.
Matt
Posts: 1,101 |
Ok guys here's a snipit of a post brad made on neco Projected price, provided I get at least 5 orders will be between $185 & 210 USD. The discrepancy comes from the 2 options. They will be available with at least 2 different types of rod ends - an 2 pc. economy or 3 pc. greasable and possibly a Teflon lined type. Also, there will be an upgrade from the std. cadmium plated bushing to a stainless bushing at the pivot point (subframe end). Time to deliver goes like this: order and receive materials, 1 wk.;machining and welding, 1-2 wks.; painting and final assembly, 1 wk.
They're fabricated from seamless DOM tubing and TIG welded. I may powder coat them, but this will add some time to delivery. They use a replaceable polyurethane bushing at the subframe mounting point and have a grease fitting for quiet operation. Expect a bit of extra stiffness, but much tighter feel. Although they're way stronger than the stock crap, I do not recommend jacking the car by the arms. They're adjustable and shipped in the stock length. It's recommended that you get a rr. suspension alignment after installation.
I was planning to do a single run in 1 colour, probably black. Yes this makes the whole process quicker & easier for me. Upon further thought, I'll consider doing 3 different colours but it could extend delivery time. Arrest me Red, Ford Blue and gloss Black. Lets see how many orders and what colours everyone wants first. As for my testing on Monday, I was horribly sick and didn't make it out to the track. However from driving on these for the past week and a half and from when I tested the last set on track back in August I can tell you that you will experience maybe a little bit more harshness from broken pavement (this is due to the better poly bushings and surprisingly the rod end set didn't add any additional harshness) but this is far out weighed but the amount of feedback thse give you about what the rear end is doing. You can really feel the rear wheels making contact with the road when cornering and driving back to back comparing the sotck arms to these was actually very enlightening. The last set I had held up amazing on the track. We put them back in the just a few weeks after and they were still perfect, unlike the stock arms. I'll let Brad chime in when they are ready to go on sale and prices are finalized More info can be found over on the NECO post
Posts: 291 |
I'll post all the details on monday 10/18 for those interested. There will be 2 colours available with optional stainless hardware upgrades. I'm still checking the cost and availability of upgraded rod ends.
TBA
Posts: 65 |
what about the non-adjustable ones, are they an option, or what? Maine winters and heim joints do not go well together.
Matt
Redneck Troll
Redneck Troll
Posts: 2,621 |
There are two colors of Ford Racing Blue, one dark and one light. The light color is shown. The darker Ford Racing Blue is almost navy, even when cured.
http://www.bnmotorsports.com
Posts: 291 |
Nope, I'm not going to do both styles. It will just end up taking me longer and complicating the whole process. However, I do have a single set which I may be willing to part with at some point in the future.
You think Maine winters are bad? They're not pretty up here either in the Great White North! If they didn't use road salt like it was going out of style, it wouldn't be as bad....
I may be able to source seals which will cover the rod ends. However, they aren't cheap as they come from an aircraft supplier and 4 will be req'd. Add something like $15-20 for a set.
Posts: 291 |
Here are the details. If you're interested in buying a set of the tubular adjustable toe control arms as pictured here email me at redcoatracing@yahoo.ca. I need your name, shipping address (including Zip/Postal code) and phone no. The base cost (economy rod ends & plated bushings) will be $185 USD plus shipping. Options will be stainless bushings at the subframe mount (+$20) and the heavy duty 3 piece, greasable rod ends (+$20). Make sure you also specify your first and second choice for colour. I'll make them in 2 different colours from Ford blue, arrest me red and black. Delivery will be approx. 4 weeks. I'll repost here on friday with the requests/replies at that time. I need a minimum of 5 orders for this to fly at these prices and I'll run the group buy for 1 wk. After the group buy the price will be higher.
Posts: 2,974 |
Brad I would be down for the set if I had the money  hopefully you will be doing this again. I see your car around Burlington alot but you never wave back. Aaron
AKA NVS SVT
98.5 Silver/Blue SVT#4553
Yeah it's modded
98 T-Red/Blue SVT Contour Totaled 06/05/06
03 3L,VCN 2000,CAT Cams,MSDS Headers w/Y-Pipe,XCal2 and lots more
Posts: 291 |
Sorry Aaron. I'm not being ignorant, probably off in my own little world. Your car is certainly unlike any other Mystiques out there! You've been a good customer, so give me a call and we'll work something out for you.
Posts: 2,974 |
Brad, no worries, I will give you a call or shoot you an e-mail within the next week  Thanks, Aaron
AKA NVS SVT
Yeah it's modded
Posts: 291 |
Hey Aaron. Calling is good, but my old hotmail address is long gone.... You can use the yahoo.ca though. Talk to you later.
Posts: 127 |
I will be up for a set of these, but it will be about 2-3 weeks before i can order
Posts: 291 |
As is the usual case on these boards, the amount of orders has been underwhelming compared to the interest shown. However, I'm in the process of making up 5 sets and once they're gone the price will be higher to reflect material cost increases. Therefore, first come first served for the first 5 pairs.
Black is the colour of choice and everyone who's placed an order wanted the HD rod ends (good choice).
Posts: 7,117 |
I am in the process of upgrading my suspension & was interested in these, but I can't see any of the pictures because the hosting site is off limits as decreed by our IS department. Could somebody be so kind as to e-mail the pictures to me?? jimr@jupiter.fl.us
Posts: 291 |
I would if I knew how, but my hand skills are more oriented to welding, machining, etc. vs. working a PC keyboard.
Let me see what I can do for you-be patient.
Posts: 7,117 |
Originally posted by Bradness: I would if I knew how, but my hand skills are more oriented to welding, machining, etc. vs. working a PC keyboard.
Thanks Brad. Anybody who can see the pictures could just copy-n-paste into an e-mail for me. It might get as hard as having to click on the little paperclip thingie and dragging them into the attachments window.
Posts: 4,760 |
Heres my thing 1st you said it will be around $125-135 and i was game at that price and i would buy a set. Originally posted by Bradness: Cost-wise we're looking at something like $125-135 for the double poly bushed type and $170-200 for the poly/spherical rod end type. The large variance in the second design is dependent on the type of rod end we supply (econo, w/ grease fitting, 2 piece, 3 piece or teflon lined). They will be offered at some kind of "special introductory" price with minimum quantities.
And now your saying its going to be 185 thats 50bucks more then what you thought they would be.. At that rate im out...
Originally posted by Bradness: Here are the details. If you're interested in buying a set of the tubular adjustable toe control arms as pictured here email me at redcoatracing@yahoo.ca. I need your name, shipping address (including Zip/Postal code) and phone no. The base cost (economy rod ends & plated bushings) will be $185 USD plus shipping. Options will be stainless bushings at the subframe mount (+$20) and the heavy duty 3 piece, greasable rod ends (+$20). Make sure you also specify your first and second choice for colour. I'll make them in 2 different colours from Ford blue, arrest me red and black. Delivery will be approx. 4 weeks. I'll repost here on friday with the requests/replies at that time. I need a minimum of 5 orders for this to fly at these prices and I'll run the group buy for 1 wk. After the group buy the price will be higher.
Team Evo
Everyone: Why?
CEG road warrior
CEG road warrior
Posts: 17,248 |
I'd be buying some but I got replace some audio equipment that was stolen last week.
Hector
257HP/259TQ
160HP/141TQ
Posts: 1,859 |
Originally posted by I-Dom-In-8: Heres my thing 1st you said it will be around $125-135 and i was game at that price and i would buy a set.
Ah bro, he said between $170-200 for rod end style, 135ish for poly bushing style. The ones he is selling are the rod end style, so price is right .
Are these planning on being limited time only. I would be intrested after the holidays have passed. Thanks
'99 Silver svt
For sale
19" Axis Neo wheels
Check classifieds
Posts: 291 |
Thanks livinsvt! I do my best to provide honest answers, responses and estimates on the parts I fabricate. I did make 1 prototype set of each type of arms, however when I added in the extra labour costs in making the double poly bushed type they ended up costing almost as much as the (superior) spherical rod end type.
Yes, I'll have a set available in the New Year especially for you. I do plan on making them on a semi-regular basis, but will not carry more than 1 or 2 sets in inventory. The ones in inventory will be whatever colour I have at that time.
Posts: 4,760 |
Originally posted by livinsvt: Originally posted by I-Dom-In-8: Heres my thing 1st you said it will be around $125-135 and i was game at that price and i would buy a set.
Then these are what i want......
Team Evo
Everyone: Why?
Posts: 1,859 |
Originally posted by I-Dom-In-8: Originally posted by livinsvt: Originally posted by I-Dom-In-8: Heres my thing 1st you said it will be around $125-135 and i was game at that price and i would buy a set.
Read above. Not worth the costs. Sperical ends are the superiour ends, so thats what will be used.
Bradness, you have a pm
'99 Silver svt
For sale
19" Axis Neo wheels
Check classifieds
Posts: 1,423 |
PM sent...would really like them in red!
Scott
Scott
2000 Contour SVT #1464
Mustang Dyno: 171.6hp/145.3lb
Dynojet Dyno: 171.1hp/148.9lb
1989 20th Anniversary Turbo T/A "Indy 500 Pace Car"
#1376 of 1550 All Original, 46k with a few mods
2002 F150 SuperCrew
Posts: 1,423 |
Ordered 2 set's, one for me and one for SVT Pete. Now the wait begins... This Spring my car will see some major suspension upgrades  1. BAT 21mm rear bar 2. Stazi S/S end links 3. Energy Suspension bushings 4. Koni's 5. Tubular toe control arms 6. Boxed rear control arms 7. May replace Eibach's with Ground Controls? Scott
Scott
2002 F150 SuperCrew
Posts: 3,867 |
Anybody know if these are legal for SCCA Solo II, STS?
If they are, I'm in trouble.
Function before fashion.
'96 Contour SE
Posts: 291 |
I've sold the first lot of 5 sets now and wanted to thank all interested parties. Due to the demand shown I will continue to fabricate them, although I expect the cost to be higher the next time I source materials.
There may be a lightweight version coming.....
Posts: 492 |
can anyone post some of the pics?
"Every normal man must be tempted at times to spit upon his hands, hoist the black flag, and begin slitting throats".--H.L. Mencken
Bumper sticker,
OXYMORON #65 - Liberal Thinker
Posts: 1,101 |
Sorry...I'll throw them back up when I had time. Had to do some configuration on my server the other week and took out part
Posts: 1,101 |
Pics are back up. I'm too tired to link them all so you can just view them all here.
Posts: 1,190 |
If you can call me and i can send you paypal or credit card and i don't have to wait forever, i will buy. 1(630)643-8669 thanks Brian
PLEASE HELP ME GET MY CAR TOGETHER! ITS IN DAYTON OHIO! I need the motor together and in the car so i can DRIVE it! Pleeeeeese!
diamond pistons for 3.0/forsale
#702 of 2150
Posts: 1,190 |
light weight version please..
#702 of 2150
Posts: 4,970 |
2005 Ford F150 SuperCab FX4
1964 Chevrolet Impala SS
Posts: 291 |
I've just about finished the initial run of tubular toe control arms. To all who've ordered them, thank you for your patience as it's taken longer than anticipated mostly due to XMas/New Years closures.
My plan was to continue to fabricate them, but in small lots of 2 or 3 pairs at a time. This will be a bit more costly, due to the better costs I receive when ordering materials in bulk. However, if there's enough interest to do another set of 5 I can minimize material cost increases.
Post, PM or email me if interested.
Posts: 710 |
How much will the next order cost.. with the HD end link? Saved up for a failed aussie bar purchase... now I need to spend that money on something else
morbid
2000 Contour SVT (black)
Posts: 291 |
Morbid: There will be an increase of $5 for the arms themselves and $5 if you wish the stainless bushing/hardware option.
I'm only going to offer them with the HD rod end anyways.
PM or email me if you're interested.
Posts: 1,423 |
Scott
2002 F150 SuperCrew
Posts: 291 |
Thanks for posting Scott. I've rec'd similiar emails from all who have rec'd them so far. Seems that winter weather is making it difficult for most to install them.
In the mean time I'm doing another run of 5. As I mentioned there will be a small cost increase to those interested in the next run ($5 base + $5 for the SS option). They'll be available in any colour you wish as long as it's Black!
Posts: 3,887 |
What are you using for materials for the tubes...chromoly steel or SS?
06 GMC Sierra 2500HD Dmax/ally
06 Pontiac G6 GT
05 CRF250R
FOR SALE 06 KX65 with riding gear $2700 obo
Posts: 3,816 |
Well recieved mine about 1 or 2 weeks ago. I was planning on installing them and taking side by side pics of what stock to these look like. These look to be of very high quality. I'll have to take em when I get back next winter. Oh well.
Awesome, though.
Posts: 3,816 |
Posts: 9,065 |
Are these still being made? Flamesuit on for not feeling like reading the whole fuggin thread.
Okay, I read it. Bradness would you be interested in another run? Any 5 ppl want in on these?
Posts: 4,140 |
Originally posted by RogerB: Anybody know if these are legal for SCCA Solo II, STS?
Pretty sure these would put you in SM. Now, the front control arm would be good as long as it has poly/delrin bushings with no more metal than the original, and are adjustable for camber. Unfortunetally, I don't see them getting made.
Posts: 5,621 |
Originally posted by MapOfTaziFoShoââ??¢: Bradness would you be interested in another run? Any 5 ppl want in on these?
Yup, like I posted in another thread, I am down.
Posts: 3,816 |
Originally posted by R_G: Originally posted by MapOfTaziFoShoââ??¢: Bradness would you be interested in another run? Any 5 ppl want in on these?
Tomorrow if my halfshaft install goes well, I should also be changing the oil up on a rack, so I'll snap some pics of them installed on the car.
Posts: 5,810 |
Very nice looking stuff Brad...as usual.
See My Mods
Posts: 9,065 |
Somebody has them for sale in the classifieds for 225$...I thought these sold for 185$ ??
Posts: 291 |
To all who are interested in my TCA's-they're still available although I'm running them off in small batches of 2-4 prs.
I (think) I have 2 pr.'s available from stock and another pr. ready to go to the TIG welder. Stuff from inventory will be shipped in under a wk. Any fabricating/welding/powder painting takes about 3 wks.
Yes, the price has risen from my initial offering. Materials have gone up a bit, but what's really hurt me is the drop in the US $. 95% of my materials are sourced here as well as the machining, welding and powder painting which must be paid in Canadian bucks. C'est la vie.
There will be a website coming shortly with all my fabricated products for Contours, Mondeos & Cougars.
PM or email me if interested. Got 1 person already.
Posts: 5,621 |
Originally posted by MapOfTaziFoShoââ??¢: Somebody has them for sale in the classifieds for 225$...I thought these sold for 185$ ??
That's Lee. I didn't get 'em from him like 2 months ago when it first appeared in the Class. - precisely for the same reason; but I am not sure about $185, I guess it was more...
Posts: 3,816 |
I paid like $220-$240 or something for mine...
Posts: 3,816 |
So since I had the car on a lift so I could do my halfshaft and oil, took a few shots of the tubular arms installed... enjoy: Big shot of both of em:  Inside part:   Do they make little covers for the lube points so they don't get all grimy?
Posts: 291 |
My first post on the TCA's offered them at a base price of $185 which included an economy type rod end. Stepping up to a heavy duty rod end was optional at $20. Since no one ever bought them with the econo rod end I do not offer it any longer and the price reflects this accordingly.
I also offered (& continue to do so) an additional cost stainless bushing & hardware option, which most people have requested also. This explains why the prices are different-plus my material costs have risen a bit since I first ran them off.
Posts: 5,621 |
Brad - your stuff looks like a great and high quality piece of work, thanks for continuing to help us. I wish you could make some more stuff for Contiques.
Kane - thanks, very useful pix; so how long it took you personally to put 'em in? Like 40 minutes?
Posts: 3,816 |
Originally posted by R_G: Kane - thanks, very useful pix; so how long it took you personally to put 'em in? Like 40 minutes?
I didn't... I had the tire shop put them in when they did the new tires and had an alignment.
But... they are very quick to change out. I've bent my original passenger one and swapped it out in probly 20 minutes once the car was jacked up.
I was suprised when I got done... I figured it would be harder.
Posts: 2,353 |
So, have you noticed any difference?
1999 Blk/Tan CSVT #654 - SOLD
2003 Suzuki SV650s
Posts: 3,816 |
Originally posted by path914: So, have you noticed any difference?
Not really... since the tires I have now have less grip than the old ones, unless the arms are doing their job...
At least I know they're not going to bend as easily.
Posts: 291 |
This thread has been going a long time and I may have explained this earlier but a bit of product development info......
I first looked at doing modified main control arms. Took the stockers off and showed them to a stock car and hot rod builder who strictly does custom chassis & suspension work. My plan was to fabricate tubular arms but he told me that a fully boxed rectangular section arm was just as strong as tubular. Plus there were other issues I was uncomfortable with: how to mount the end link; installation of main arms requires dropping the subframe for bolt removal; potential failure due to the fact that the main arms carry the majority of the rear suspension loads. Then add in the fact that the stock Ford toe control arms are flimsy, disposable products, relatively simple to install and the decision was made for me.
There are some comments & opinions of the tubular TCA's on the NECO board by at least 1 fellow who autocrosses his Cougar. If you cannot find it PM me and I'll see if I can find the link.
Posts: 611 |
Why would you need to drop the subframe to get the A-arms out? You can just cut the bolt on the transmission side and run the new bolt in from under neath when you install it.
1999 3.0L Cougar: 220fwhp and 200tq
2003 VW Passat W8 with 4 Motion AWD
http://www.cardomain.com/ride/300644
PM for intrest in 3L SVT Contours, 3L swaps into your current car, Prepped 3L engines, or anything 3L related.
Posts: 1,101 |
Originally posted by Blackcoog: Why would you need to drop the subframe to get the A-arms out? You can just cut the bolt on the transmission side and run the new bolt in from under neath when you install it.
I think you are takling about the front A-arms, and Brad was talking about the rear control arm (box-like arm).
Now about what you suggested, I won't get into this fully, but think about it this way. With the bolts in from the top, if the nut backs off you are still okay, if they are inserted through the bottom and the nut backs off, out drops the bolt and you can take it from there....
Brad and myself see eye to eye on this and discussed it a while back.
Posts: 5,621 |
Got my TCAs from Brad. Looks amazing - gotta post more after I put 'em on.
Posts: 291 |
This thread is kinda' old but still hanging around.
Anyhow, I've got some excess inventory (3 prs.) of these arms which I'm unloading at a sale price. They normally sell for $225 plus options & shipping. I'll let them go for $200 US plus shipping. They come with zinc plated sleeve/bushings/hardware and are painted black. 1 pair has a small paint blemish which is nearly completely hidden by the poly bushings, another has a very light silver speckle in the black powder paint only apparent when looking closely. The painter didn't clean out the gun fully.
Payment to be by Money Order or personal cheque. Sorry but Paypal skims too much for me to make this offer and use them for payment.
Anyone interested should PM or email me.
Posts: 5,600 |
I am still interested, however I am about to leave the country for 1 month so this isnt the best time for me. . . .
I was also thinking getting a few other parts from you at the same time and just do one big fun purchase.
Black 1998.5 CSVT
Posts: 3,335 |
Im still happy with mine. They are moving over to my Cougar as soon as it comes home.
· Jon Miconi
· Coming Soon!
· 01 Cougar
· 98 V70R
Posts: 291 |
Hey Jon. You getting rid of (1) your Contours or simply adding to the fleet?
I'm happy to advise that the first set I put into service nearly 2 yrs. ago are still going strong. They've seen 2 local winters c/w slush, salt, sand, snow, etc. as is the norm around here.
Glad that everyone likes 'em.
Posts: 3,335 |
The `98 was a builder, the `96 is up in the air and the Cougar is the `96's replacement, only with a V6, leather and a better color. Still need to keep a toy since the Volvo handles the twisties best if its parked and I am looking at them.
· Jon Miconi
· Coming Soon!
· 01 Cougar
· 98 V70R
Posts: 8 |
YES! Looking to replace my shot lower control arms ASAP. Please bring to market now and let me know when you do!
Chris Caselli
'67 Mustang Fastback project car
'98 SVT Contour daily driver
Posts: 3,816 |
Originally posted by Bradness: I'm happy to advise that the first set I put into service nearly 2 yrs. ago are still going strong. They've seen 2 local winters c/w slush, salt, sand, snow, etc. as is the norm around here.
Mine have seen some aggressive driving on these German twisites... work perfect!
Was looking at tire wear the other day, both back tires look brand new, so no alignment issues with them either!
They have gone through:
Trip from Montana to Iowa to Wyoming to Idaho to Montana to Seattle with heavy snow, getting stuck on a mountain pass with a tow from a Forest ranger over the top, and various amounts of mud/dirt everywhere from that adventure. Trip via ship to Germany German winter German roads (note that roads suck pretty bad here)
Posts: 937 |
Well, I guess these are really nice...
Paid my $235 and Brad mailed them out to me on 23 June.
And that�s the end of that.
The Canada Post tracking shows (today at 6:30PM):
Date of Even Time of Event Location Description
2006/06/23 09:52 BURLINGTON, ON Item accepted at the Post office
and nothing else.
My local US Post Office says no package has arrived for me from Canada. The Canadian post office sent me this automated reply when I asked where my package was (seven days ago).
We are currently experiencing a rapid increase in e-mail requests from our customers.
This has caused delays in our ability to respond to your request. Thank you for your patience and understanding.
Right...
Is it still sitting at the Burlington ON post office? How long does a delivery take? Will I think twice before I buy anything that has to be shipped from Canada? Does anyone stateside have a set of these they never installed ($$)?
These are questions awaiting answers!
If I don't hear anything by next week, I will give up on it, see if Brad bought insurance for me - and try to find another set of these somewhere. Looks like a real nice product.
99 Tropic Green SVT, Tan Leather, 20K miles, "Nice Twin" (factory stock).
99 Tropic Green SVT, Tan Leather, 28K miles, "Evil Twin" (Turbo AER 3L and more in progress)
96 Red LX, Opal Grey Leather 2.5L, ATX, 22K miles
Posts: 5,600 |
When Brad sent me my RSTB, shipping took ~1 week, nothing out of the ordinary. I wonder what the hold up is?
Black 1998.5 CSVT
Posts: 937 |
Since I know from PMs that at least one other CEGer has been having similar trouble with shipping on this, I thought I'd post what I've found out.
I've tried contacting Canada Post by both email and by telephone. Emails are worthless. My emails are answered with apologies about how busy they are or a short message that I must wait 30 days to start a trace (it has been well over 30 days). Today I spent 45 minutes on hold on a long distance international line (God knows what that cost), trying to start a trace and was finally told that the sender must initiate traces. I�m not sure if that�s an international restriction or not.
So anyone in the US who has not received his parts after 30 days must ask Brad to start a ââ?¬Å?trace.ââ?¬Â At the completion of the trace (probably another 30 days) CanadaPost will honor the insurance ($200 US in my case) if the sender (Brad) requests it.
If the insurance comes through, I guess I�m only out the $35 shipping and phone bills.
Whole thing sucks, but is not Brad�s fault in any way.
Posts: 710 |
Did they make it to the Canada/USA exchange? My arms were held up about 1 week at the border. Also, the Canada Post tracking only goes to the border.... I think from there, you can use the # in the USPS tracking.
morbid
Posts: 937 |
Originally posted by morbid: Did they make it to the Canada/USA exchange? My arms were held up about 1 week at the border. Also, the Canada Post tracking only goes to the border.... I think from there, you can use the # in the USPS tracking.
I have no way of knowing where they are. Canada Post tracking only shows Brad dropping them off. Nothing has arrived at my post office.
Posts: 937 |
35 days, including the day Brad mailed the parts. That's what it took to ship from Burlington ON to Marshall VA.
I got my package. The tube was leaning on the wall of my housenext to my front door when I got home today.
Figures it would show up the very day after I decide to get serious about starting a trace!
Posts: 1,336 |
Should have gone FedEx
Posts: 533 |
mine arrived safe and sound. thanks brad!
-a
koni kit - hpp rstb
camber/plates - cf (yikes!)
polyroll resistors - TCA's
WR headers/ypipe -TB hiflow cat
SFC's - XCal2
-dreaming of 3L-
Posts: 3,816 |
Maybe they're held up in customs?
