Page 2 of 2 1 2
CV6MTX Offline OP
If you'd like to speak to the guy doing the P&P work, his name is Chris, and his email is... rawsprobegt@juno.com
Feel free to email him and ask anything ya like...he's a real good guy.
1995 Probe GT ATX TOO MANY MODS
1999 Cougar V6 MTX
Stage 1: (Basic Mods)B&M STS, Bassani Exhaust, KKM intake w/ weapon R pipe, ProFlow 75mm MAF w/optimiser, YoDude Y-pipe w/hi flow cat, SVT TB, SVT Upper IM, OMP FSTB,AF gauge, Aerogear fiberglass hood (completed)
Stage 2: (Top End Work) 19-24lb injectors, P&P heads w larger valves and HPC coated, P&P and port matched lower intake manifold also HPC coated, custom ground cams, Ford Racing 9mm wires, Bosch +4 plugs, Custom burned PAC or Diablo chip (will dyno with both), Apexi SAFC (In Progress)
Stage 3: (Transmission) Quaife LSD, CM stage 3 Clutch, Fidanza flywheel (In progress)
Stage 4: (Suspension)Koni adjustibles, H&R springs, Progress 21mm rear anti sway bar (Installing on Tues)
Current dyno: 172.9 whp with just bolt ons and stock exhaust manifolds (not gutted), oh, and bad wires smile...
im interested in some head work too
/me walks into another wall
-Speed Demon- Matt
Black 2000 Contour SE Sport (duratec/atx)
got body mods?
all show, better than stock go smile
"I might be crazy, but I'm not stupid"
speddmn.com
[QUOTE]Originally posted by CV6MTX:
Does anyone know id the SVT cams are different or the same to the stock duratec ones? I have been told soooo many diferent things, I have no idea what's true, and what's not.
According to Ford, the SVT cams are hotter. I found the actual specs in some SVT sales training information a year or two ago, but I don't know where I put the print out. It was posted on the Contour L list if someone wants to do a search.
Jim Johnson
98 SVT
Master P
Master P
http://www.coldair.org/archives/9912/msg01590.html
Page 2 of 2 1 2
