ktung Offline OP
I'm kind of stuck here. I would like to know how you guys who have done their cv joints before, how you guys got the driveaxle out of the tranny. I have tried and tried and it's not budging. Were you guys doing it from under the car? Used any special tools? I was thinking of bending a crow bar into a L so then i can just pry it off. I'm just trying to find a simple way to go about it. I simply thought you could just pull it out. What are your suggestions? Thanks.
Kevin
I used a ball joint seperator. Try it.
ktung Offline OP
too bad i don't have any of those. i couldn't get the balljoint off so i just grinded the rivets off and pounded away.
try harder!!!
98 svt sil/blu 3.0 oval heads full P&P, msds headers,bat kit,2,1/2exhaust 30 inch glasspack and 2 spintech mufflers 14.78@94mph with my mechanical arm i can shift gears in less then a twentieth of a second for sale $7000
From under the car - I've used a small axe, wedged the sharp end between the tranny and axle, and hit the dull end with a rubber mallet.
T.
I used a 6' piece of wood, 2x4 and wedged in between housing
and shaft and pryed it out...better leverage and won't damage anything. Driver side was tougher than passenger side, but just a good force and it came out.
ktung Offline OP
thanks guys. someone could have warned me about the major fluid spillage. but it's all good. Thanks.
