#1003559 07/14/04 03:29 AM
does anyone have a procedure to remove the shifter from a 1999 svt contour? the 2 front torx screws were real tight trying to back out, so I stopped. The 2000 was easy, but the '99 is a little different. Thanks, Thom
#1003560 07/14/04 04:00 AM
The R&R procedure is the same on every cable shifter.
#1003561 07/17/04 01:57 AM
Should the front two torx scews unscrew? I didn't want to force it, it's not my car. I have a 2000, it took me about 30 mins. to install it in mine. the 99 even looks alittle different but they both use the same shifter. Thanks for your response!!!
#1003562 07/17/04 02:09 AM
You installed one in your car, but don't know if you're supposed to unscrew the two torx screws?
Yes. You are.
"...first he's gonna s*!t, then he's gonna kill us." 1999 Contour SVT Retrojunk.com
#1003563 07/17/04 05:10 AM
Have you had the shifter off on yours? Did the torx screws get harder to loosen the more you turned? On my 2000 they came right off, but the 99 feels like they are close to breaking or stripping, that's why I stopped.
#1003564 07/18/04 01:33 AM
I have a 98. They all came out. Some were harder than others but they all came out.
AIM...BKapp17 98 T-red SVT Steeda Gutted Pre-cats, no resonator Painted Dash Angel Eye Fogs Painted Chrome ring / headlights Looking for a t-red pre98 trunk lid
#1003565 07/18/04 02:12 AM
I
I
when ford put the cars together, the used some thread lock on those screws to keep them from working loose. If these screws have never been loosened, they could be a little tight. If you mess them up, or want to change them to hex head (allen wrench), let me know, I've got a box of them. When you install them you should use some thread lock.
contours, deloreans & fiats, oh my!
