Posts: 70 |
How many clamps did you have to buy?
Posts: 3,195 |
Originally posted by SleeperZ:
There's a 90 degree 2.75" to 2.75" elbow on the TB. And a 45 degree 2.75" to 3" elbow on the MAF. Seemless and snug fit on the TB, tubing, and MAF. The 90 degree elbow has a long radius bend. The tubing is stainless steel (which will be be getting a heat resistant coating in black).
How many do you see?
1999 Sportage 4x4...don't go there, it was free
....______o_o
.../_l l__\____\
..|--l l__----[]\|/[]
.....................oo
=( )_)----( )_)--)_)
Posts: 70 |
I can't see all of them, hence the question.
Posts: 8,301 |
Looks like 4. If nothing else, get an extra in case you need another.
-Ken V.
psycho_bass@hotmail.com
Posts: 3,195 |
Originally posted by nimrod: I can't see all of them, hence the question.
each elbow needs 2...how many elbows/couplers do you see? (elbows can be various degrees, 90, 45, etc)
....______o_o
.../_l l__\____\
Posts: 2,483 |
Yes, total of four clamps.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
Posts: 44 |
SleeperZ, what type of K&N filter do you have? Is it just the flat, stock replacement filter?
1996 Contour GL, Zetec, ATX, Midnight Blue
Mods:
custom exhaust
after-market spoiler
Knauberized
Posts: 2,483 |
Originally posted by CONTOURCODY: SleeperZ, what type of K&N filter do you have? Is it just the flat, stock replacement filter?
Yes
Posts: 937 |
Originally posted by SleeperZ: Here's a pic of my engine bay, not just for a little whoring, but to show what a proper sized (2.75") intake looks like.
As far as perfomance compared to other intakes; Short Ram (CTA intake) - high temp, low pressure, high cfm Short Ram w/ Heat Shield - mid temp, low pressure, mid cfm CAI (CTA w/ GMK extension) - low temp, high pressure, low cfm My intake - low temp, mid pressure, high cfm
Cost = less than $90 (with K&N filter)
What are the Part #'s again? http://www.ajusa.com/cgi-bin/injen/universal?category=HOSES
And the from here as well.. Thanks! http://www.atpturbo.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=tp&Category_Code=SIL-STR
Posts: 2,483 |
From Aj-USA; X-3004 - 90 degree on TB X-3003 - 45 degree on MAF
From ATP; ATP-STL-007 - 2.75" stainless steel piping or ATP-ALM-001 - 2.75" aluminum piping
You should use stainless steel to help keep intake temps down. If you go with aluminum, you can either paint it with high temp engine paint (that has ceramic in it) or wrap with exhaust wrap, to help keep intake temps down.
