Page 2 of 3 1 2 3
TGO Offline
There's a bunch of stuff that can go wrong, but I had a 95 mystique sitting for a year and a half, outdoors, and it started right up...after i replaced the battery (which was going bad when we stopped driving the car...and IIRC it was the original unit). car started right up. I recommended changing the oil to my parents, but it's their car and their problem so i don' tknow if they ever did.
1999 Silver Frost SVT #609 of 2760 Quaife, lightened SVT Flywheel, SPEC stage II clutch, removed resonator, k&n drop in - various other goodies too.
I'm in the process of resurrecting several abandoned Subaru's, so maybe we can help each other out? Of course, my cars have sat for at least 5 years. I doubt you'll have all the same problems I'm having/will have, though.
Since the fuel goes to pot after such a long time, you gotta drain the fuel tank. Not only that, but bear in mind that there's all that gunk in your fuel system; ie: lines, injectors, etc. All that gunk will eventually work its way out, but at the exspense of your injectors and spark plugs. Don't bother buying a nice set of spark plugs right away. A set of $1 plugs will do fine, since they'll gunk up pretty soon anyway. Clean the injectors and plugs as often as possible, as well as change the oil as often as possible. Also flush the coolant along with the oil changes. Basically, all the fluids in the car are crap, and you've got to get them out before any damage is done to the car. As with any oil change, replace the oil filter, too. Replace it each time you change the oil; as the oil will be full of junk, too.
Of course change the obvious things like the battery, air filter, and maybe spark plug wires; depending on milage.
It'll take a little while to get the motor and tranny back to their original running condition. I'd run premium gas and a bottle of fuel injector cleaner in every tank for a while to be sure.
I hope you don't have the same problem with ants that I do.
2000 Contour SE 2.5L ATX - Toreador Red 2001 VW Golf GLS 2.0L MTX - Tornado Red Buy my possessed VCR!!
Reminder to self: let car sit for months.
N
N
ahhh so THAT'S where pot comes from!
1998 T-Red CSVT 3.0L
Yeap. Ya learn something new everyday.
My car started right up after not running for a year.
Originally posted by BIG daDDy:
What should my biggest concerns be about my car and the fact that it has been driven twice since 3/2003 and only started up a few times? I am finally going to sell it and I just want to know what things I can do to prepare her for the sale. It is a 99 se v/6 5 spd with 80k miles. Brakes were done at 60k, roush springs and st/200 struts were put in at 78k, new plugs and ford racing wires were done at 70k. I also had the tranny fluid changed and added the friction modifier(it already has a synchro problem) My biggest concerns are things like gaskets drying out. Anything else I should be worried about? Anti freeze was never changed since I bought it so I know that should be done. Are the other cheap and easy things to do like cleaning the intakes that I could do myself? I am somewhat mechanically inclined but not great and my access to the car is limited because I live in NYC and the car is in Boston. I would be coming home for 2 days at best to get things done to it.
I doubt that you will have many problems. Cars often sit on dealer's lots that long and sometimes even longer with no problems. From what you have said, I would be most concerned about the original anti freeze.
Stale gas has a very distinctive odor. Sniff the gas tank and if the fuel smells normal (if the gas is stale, you will know immediately, it is that unusual) go ahead and start the engine then see how it runs with a short road test. If everything seems OK, change the oil and drive it home. Do change the coolant very soon, and carefully check to make sure that the radiator has not sprung a leak where the side tanks join the main core.
If you know you are going to store a car, it should be stored with a full tank of fuel and reasonably fresh oil as well as anti freeze that isn't much more than a year old.
I doubt if the picture is as gloomy as some have painted it.
Y
Y
Remember to the general public that knows nothing about cars, if a car sits and doesn't run, it is "saved".
I.E, you can say the car was "stored and therefore the mileage is low". People will eat it up.
Some will say "I have my late great aunt's 1979 AMC Pacer, it must be a classic, and it's well preserved from sitting in the garage for 10 years!"
2005 Nissan Sentra 1.8 SE, Code Red. '00 Tropic Green Ford Escort SE [Contour's little cousin]
yeah, his transmission isnt in the trunk
-Ken V. 1998.5 SE Praire Tan Zetec ATX psycho_bass@hotmail.com Roush springs Roush rear sway bar BAT struts 17" Millie Miglia HT3 and a ton of subtle asthetic mods
I
I
this thread is scaring me
my car has been sitting for 2 months with a blown headgasket and I've got a lil water in the oil plus the gas is still there.
I've heard that the piston rings can rust from this? I hope I'm ok.
Page 2 of 3 1 2 3
