Posts: 1,812 |
although, a one time dyno tuning sounds like more fun than *buy chip, install chip, pray, be disappointed w/ chip, send chip back, pray* (repeat as necessary) BTW, where does one place that beautiful piece of equipment? dash?
2000 Silver SVT #1602 Check it out in the registry! Mi Coche
Posts: 1,003 |
Mine's going to go in the second DIN slot right under my gee-whizz looking Kenwood head-unit. Together they should make the car look like some kinda wierd video game.
Brad- way ahead of you on the ITC. As with the S-AFC, it looks real nice, but have you checked to see if it's going to be compatible w/the stock EEC? I havn't read the info on the ITC on APEX-i's website yet.
Posts: 7,329 |
Chip with a preset spark advance curve (not Ford's random advance timing :rolleyes: ) Pot resistor on IAT S-AFC for full range A/F tuning I don't see the benefit...
Posts: 1,812 |
Originally posted by DemonSVT: Chip with a preset spark advance curve (not Ford's random advance timing :rolleyes: ) Pot resistor on IAT S-AFC for full range A/F tuning
I don't see the benefit...  yeah, sounds like hogwash to me (although the pot/IAT is an area I'm lacking knowledge in, I admit)
Posts: 4,899 |
The 'Cardoc IAT resistor mod' as it is called is great. I use it, and the power gain in high RPM is great.
Posts: 3,237 |
Originally posted by bnoon:
That's what the Apexi ITC is for. Granted you still have to do something with the rev limiter...And that thing is WAY cheap right now, like $150 orsomething crazy like that. But you can go BOOM in a big hurry with that thing if you put in too much advance. I am weary of that gizmo. Without real "on the dyno" tuning I wouldn't touch the ITC. All the same, something has to be done to the poor ignition timing control my 2000 has. It sux!
Posts: 3,562 |
As easy as these engines "talk" to you when they have to much advance, you'd be hard pressed to not know when they're getting detonation. Grab your Autotap or other OBD-II program and set it up. The fuel trim via the S_AFC is going to be the tricky part... Need a wide band sensor to do it right, keep that one for the dyno for sure.
The ITC should be compatable since it mostly works on a crank/cam magnetic sensor delay and sends a false signal towards the ECU. We have both the crank and cam sensor, so it may be just "pick one" to make it work. Not sure until I find a set of instructions or full write up to know for sure...
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 7,329 |
I'm content with a pre-set spark curve of my chosing... I have it all plotted out for when I send my chip back to get re-flashed. All sorts of good stuff going on... The resistor can be used to alter part thottle timing. Since it uses the Chips/PCMs tables during WOT. The S-AFC can modify chip fuel tuning without the need for the chip to be re-flashed once you have your optimum advance curve, redline, & secondary point (for those who will have them :rolleyes: ). Yes I ordered one...  Even if I made half the IS300's gains 7HP/6TQ - that beats nearly any other mod. 10/10?, 15/10? for ~$400... Plus the ability to "re-tune" it later... ...and a laptop to record it all on... I promise to share...
Administrator
Administrator
Posts: 5,037 |
Originally posted by DemonSVT: ...Yes I ordered one... So you got the AFC or the ITC?
Posts: 7,329 |
