Posts: 340 |
Originally posted by Kremithefrog: Like intake manifold gaskets??? If so, talk to many duratec owners if you wanna hear about leaky gaskets.
Leaking coolant, vacuum...???
Before or after they've worked on their motor?
After they've switched to DexCool?
Again, I can't remember that last Ford Intake that I've had off due to coolant leaking at a coolant passage, but I've done/seen around 50 GM leaks in about the last 3 or so years.
Posts: 340 |
b.t.w. Seems like you're being specific here, not just Fords in general...we're talking about coolant leaks and clogged coolant passages in intakes/heads, and you bring up leaky intake gaskets on Duratecs...why?
You see coolant passages in their upper/lower intake gaskets that I don't see?
Coolant is getting in their fuel rails?
Posts: 21,653 |
See the first thing I said is followed by a question mark. I was unsure if you were changing the subject and I asked though you never answered, just tried to aruge. I'm trying to discuss. I'm done with this thread and the thermostat thread just so you know because I know you want to continue to argue, PM me in that case and keep it off the threads.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 340 |
Originally posted by Kremithefrog: See the first thing I said is followed by a question mark. I was unsure if you were changing the subject and I asked though you never answered, just tried to aruge. I'm trying to discuss. I'm done with this thread and the thermostat thread just so you know because I know you want to continue to argue, PM me in that case and keep it off the threads.
"If so, talk to many duratec owners if you wanna hear about leaky gaskets."
See, it seems that you're trying to imply that coolant leaks are a problem at the intake gaskets on the Duratec, only because you tried to discredit my statement about leaks with GM's engines, using DexCool vs. Ford's engines that don't come equipped with DexCool...you never answered why I should ask about intake gaskets that leak coolant, even tho' there isn't any possible way for those intake gaskets to leak coolant.
If you don't want it on the threads, why did you ask it on the threads?
