Posts: 100 |
I got 87,500 on my Contour and I have a completely rebuilt tranny to show for it. I still think it's a great car for the price though [I knew ATX was a weak point ahead of time]. I had no other problems with a car whatsoever and I hear Zetecs are actually pretty reliable engines. What mileage have you got on your car and what's your repair history like?
Contour '97GL 2L ATX, ~100k
Pioneer sound system
A few unintentional scratches on the back and a rebuilt tranny
Posts: 8,301 |
72K Repair history- zip, nada, zero  *knocks on wood repeatedly*
-Ken V.
psycho_bass@hotmail.com
Posts: 2,489 |
51k repair history: timing belt change
had some problems and a CEL a few months ago, but it turned out to be a bad tank of gas. otherwise, perfect so far
1998 T-Red CSVT 3.0L
Posts: 2,725 |
Originally posted by lovemycontour: I got 87,500 on my Contour and I have a completely rebuilt tranny to show for it. I still think it's a great car for the price though [I knew ATX was a weak point ahead of time]. I had no other problems with a car whatsoever and I hear Zetecs are actually pretty reliable engines. What mileage have you got on your car and what's your repair history like?
Well some people have good luck, it is a great car but I swear mine was built on a Friday. 47k-65k, radiator, serp belt, hood wouldnt open latch broke, TSS sensor leaked after replacement, shifter indicator broke, wheel cylinders leaked, needed to replace cylinders/shoes/drums hardware kit, brake fluid was all over the place, heater switch but Ford covered it, needed an O2 sensor but that wasnt a big deal, up and downstream though, drivers side power window switch, right headlight assembly cracked needed replacement, passanger side window black seal, slight leak. Several littel parts to have broke to, washer nozzle, thing that holds the hood support ( yellow clip), near the passanger side where they would rest their left leg, that broke apart from one of the locations for some reason one day. So I dont know I have always done maintance to it, but it still gives me [censored].
Posts: 8,143 |
124k MILES
replaced timing belt bad 02 sensor dirty maf low ac stuff blown headgasket
currently not running because of the last one.
thats about it.
Posts: 21,653 |
About 110k miles-
Other than preventative maintenance and some small non-engine stuff, all I've HAD to do is change the top o2 sensor, twice, and replace a couple pulleys.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 2,489 |
thats about it.
that sucks man...how much $$ to fix?
Posts: 331 |
i have about 87k and have had no problems other than flat tires
99 Zetec Atx Se
17's w/yoko H4 rubber
Green and Black interior
CTA + header + big pipes = very loud
89 Mustang LX (stock for now)
Zippy Zetec on his last legs.
Posts: 1,262 |
84K (actually, 83,376 to be exact)
A/C compressor clutch (needss done) IAC valve Timing Belt wheel bearing
and thats about it...as for preventative maint:
waterpump (while the TB was being changed) Serp belt (same)
and regular maint: tires, spark plugs and wires air filter brakes
everything else, i have done as mods....and no, i still havent replaced the muffler...at 83,376 miles it shows no sign of needing replaced.
but i do have a hole in my catalytic converter somewhere...
Regards, Cole.
Relegating to troll status sometime this week.
New Whip: 1990 Lexus ES250.
Old Hotness: 1995 GL MTX Zetec *IN TRIAGE*
"I had a little friend once, but it dont move no more...  "
Posts: 5,143 |
105K Running goood
Timing belt Passenger rear Brake done (did with help of dad and uncle) Plugs, wires, coil 2 wheel bearings Thermostat
I might need a fuel pump in the near future. But im not really sure yet.
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
