H
H
or how many miles you have on it if you never replaced it.
Another thing see I have been on the board for a while, still not sure what years the fuel pump problem is for though.
thanks
factory one for about 120k (7yrs) 1st replacement (autozone) for 40k (2yrs), 3rd one (autozone) installed 3 weeks ago.
I noticed that even with the brand new pump I can feel (very slightly though) that the car runs less well if the tank is almost empty.
This means that either autozone sells crap, or I don't know how to install a pump or there's something wrong somewhere
else. Maybe I'll replace the fuel pressure regulator and see if that helps.
Tiv
H
H
Tiv
Think your problem is Autozone, Motorcraft 120k, Autozone 40k. See what I'm saying, go to Ford and buy another Motorcraft one.
72K on the original pump. I run it low enough to have the gas light on every time.
-Ken V. 1998.5 SE Praire Tan Zetec ATX psycho_bass@hotmail.com Roush springs Roush rear sway bar BAT struts 17" Millie Miglia HT3 and a ton of subtle asthetic mods
0
57,8xx on the original pump. Car hesitates, stutters, spits, spats, carrys on etc. if I step on it at anything less than half a tank.
Turbocharged trolling around here somewhere. Beat your wife, Potvin, beat your wife! True Blue 06...err...07~LET'S GO RANGERS!!
original at 126k and I run it to the red on the gas guage
Never had a pump failure on the tour(s), but I once had to put an aftermarket pump on an old Mazda -- somebody crawled under the car and stole the stock one! -- and the replacement sounded like a damn woodpecker! So yeah, some aftermarket ones are crappy. I forget where I got that one...
Zippy Zetec on his last legs.
83,376 (as of thismorning when i parkedit) and no signs of wear...
Regards, Cole. Relegating to troll status sometime this week. New Whip: 1990 Lexus ES250. Old Hotness: 1995 GL MTX Zetec *IN TRIAGE* "I had a little friend once, but it dont move no more... "
thanks
40,860...as quiet as can be.
I try not to ever go under a quarter of a tank.
128K before failure and I run it until the low fuel light is on. Would have probably lasted longer if the sending unit didn't go out because of a couple tanks of bad Ashland/Marathon gas. Turns out that Ashland/Marathon had some problems in the Louisville area with Sulphur, which causes the fuel pump sending units to seize.
'99 Contour LX 2.0L 4 Cyl Everything Stock
