Posts: 2,725 |
or how many miles you have on it if you never replaced it.
Another thing see I have been on the board for a while, still not sure what years the fuel pump problem is for though.
thanks
Posts: 750 |
factory one for about 120k (7yrs) 1st replacement (autozone) for 40k (2yrs), 3rd one (autozone) installed 3 weeks ago.
I noticed that even with the brand new pump I can feel (very slightly though) that the car runs less well if the tank is almost empty. This means that either autozone sells crap, or I don't know how to install a pump or there's something wrong somewhere else. Maybe I'll replace the fuel pressure regulator and see if that helps.
Tiv
Posts: 2,725 |
Originally posted by tiv: factory one for about 120k (7yrs) 1st replacement (autozone) for 40k (2yrs), 3rd one (autozone) installed 3 weeks ago.
Tiv
Think your problem is Autozone, Motorcraft 120k, Autozone 40k. See what I'm saying, go to Ford and buy another Motorcraft one.
Posts: 8,301 |
72K on the original pump. I run it low enough to have the gas light on every time.
-Ken V.
psycho_bass@hotmail.com
Posts: 869 |
57,8xx on the original pump. Car hesitates, stutters, spits, spats, carrys on etc. if I step on it at anything less than half a tank.
Turbocharged trolling around here somewhere.
Beat your wife, Potvin, beat your wife!
True Blue 06...err...07~LET'S GO RANGERS!!
Posts: 6,910 |
original at 126k and I run it to the red on the gas guage
- 95 Mystique LS - Zetec/5spd
Posts: 682 |
Never had a pump failure on the tour(s), but I once had to put an aftermarket pump on an old Mazda -- somebody crawled under the car and stole the stock one! -- and the replacement sounded like a damn woodpecker! So yeah, some aftermarket ones are crappy. I forget where I got that one...
Zippy Zetec on his last legs.
Posts: 1,262 |
83,376 (as of thismorning when i parkedit) and no signs of wear...
Regards, Cole.
Relegating to troll status sometime this week.
New Whip: 1990 Lexus ES250.
Old Hotness: 1995 GL MTX Zetec *IN TRIAGE*
"I had a little friend once, but it dont move no more...  "
Posts: 340 |
Originally posted by HITMANinMI: or how many miles you have on it if you never replaced it.
thanks
40,860...as quiet as can be.
I try not to ever go under a quarter of a tank.
Posts: 14 |
128K before failure and I run it until the low fuel light is on. Would have probably lasted longer if the sending unit didn't go out because of a couple tanks of bad Ashland/Marathon gas. Turns out that Ashland/Marathon had some problems in the Louisville area with Sulphur, which causes the fuel pump sending units to seize.
'99 Contour LX
2.0L 4 Cyl
Everything Stock
