Page 2 of 3 1 2 3
#1001614 07/13/04 11:10 PM
R_G Offline
Originally posted by emartinez13:
You know what, I didn't do that and I thought about it but I didn't think it would make a difference. I am going to try it. Just out of curiousity, why should it be necessary to do that? I mean you would think that if you replace the malfunctioning part that it would automatically just work, but I guess not. Thanks for the suggestion.
Something I just remembered, shouldn't the computer be reset by pulling fuse 4 and 11 rather than by the negative cable? Or will both do the job?
Yup, 4 and 11, less time/effort consuming.
#1001615 07/14/04 03:08 AM
Where are 4 and 11 at?
#1001616 07/14/04 12:29 PM
E
E
They are in the fuse box under the hood, next to the battery.
95 Gl Zetec Atx
#1001617 07/14/04 05:52 PM
F
F
Originally posted by Paul Kienitz:
For me, if the idle started surging up and down, it was always just a dirty MAF symptom. Good to know there is another thing that can cause it.
I wish that's all it was, would be a cheap fix. I have cleaned it and it didn't do anything. Anyways...here's an update to replacing the IAC. Took me about 30 minutes to get the old one off and put the new one on. Unfortunately, that didn't fix my problem Anyone have any other suggestions? I have cleaned maf, replaced pcv valve, cleaned throttle body, replaced egr valve, replaced dpfe, checked idle increase solenoid (was good), the air filter is still clean. What am I missing? Maybe a new PCM
I'd suggest checking the TPS sensor. It's just a 3 wire pot.
96 Sport 2.0L - 190,XXX miles
#1001618 07/14/04 07:31 PM
I know, I meant like, how do you know which is 4 and 11?
#1001619 07/14/04 07:40 PM
E
E
When you take the cover off the fuse box, it has a diagram on the fuse box cover on the inside, and it tells you which fuse is which.
95 Gl Zetec Atx
#1001620 07/14/04 07:43 PM
E
E
Well, I tried to test the TPS but I couldn't since it's so close to the firewall, couldn't get my hands behind it nor could I see the terminals to make sure i'm testing the correct ones. Any suggestions? Other than taking it off the throttle body?
95 Gl Zetec Atx
#1001621 07/14/04 08:27 PM
Yeah, I found it, I don't know why I never noticed it before.
#1001622 07/15/04 01:23 AM
Hey just trying to do my part here- bad MAP sensor? I had a 89 Ford Tempo have one go bad, and it kept reving from low to high on it's own. That's my $.02...
[color:"green"]-Matt R
'99 Tropic Green LX, Zetec, ATX
#1001623 07/15/04 12:43 PM
E
E
I don't think these cars have MAP sensors...did you mean a MAF sensor, maybe?
95 Gl Zetec Atx
Page 2 of 3 1 2 3
