Ok, I thought it was supposed to be easy to bypass the factory amp on these cars. I bought the bypass harness, found my amp, unplugged the two connectors going to it, went to put the bypass harness on and it doesn't fit. The bypass harness has two ends that essentially look the same. However, the two connectors that go to the amp look totally different. One is rectangular and the other is a square 8 pin connector. The wires going to this connector have a grey wrapping on them. I did a search but didn't find an adequate answer. Can anyone help? I've heard that there are two different amps out there. Did I just get the wrong bypass harness (I don't think I did) or is there more to this? And why can't attach images anymore?
